Old 07-18-2018, 12:17 PM   #15
tyler_win_photo
tyler_win_photo's Avatar
Is there a reason you don't want mufflers?
Asking for an exhaust without mufflers that's also quiet is like having a baby and expecting it not to cry.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
humfrz (07-18-2018)
Old 07-18-2018, 05:10 PM   #16
gpvecchi
gpvecchi's Avatar
A muffler is a silencer made with different chambers, and gases slow down in them, while a resonator is a straight drilled pipe with some glass absorbent around it. I previously had a NA 2000 cc with 180 HP, and I swapped 63 mm exhusts with 60 mm, and I noticed the difference (dyno too). Perhaps I'm sensitive. Supersprint factory is 30 km from my house, they don't use mufflers.
Muffler and resonators: https://www.cjponyparts.com/resource...-vs-resonators
gpvecchi is offline   Reply With Quote
Old 07-18-2018, 06:14 PM   #17
Trust86
Drives: 2016 Halo FRS
They make straight through mufflers too
Trust86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trust86 For This Useful Post:
G-Man (07-18-2018), humfrz (07-18-2018), monkeybike (07-18-2018)
Old 07-18-2018, 06:21 PM   #18
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Mufflers are made to lessen sound, resonators are made to remove certain frequencies of sound.
Different types of mufflers
https://www.streetmusclemag.com/tech...on-strategies/
what resonators vs mufflers do
https://www.americanmuscle.com/musta...ifference.html
G-Man is offline   Reply With Quote
Old 07-18-2018, 06:35 PM   #19
15limited
15limited's Avatar
But how much of a difference? Did you swap out the entire exhaust, or just the catback/axleback? Nobody doubts piping size makes a difference and that theres a tradeoff between mufflers and resonators. If there was a quiet, muffled, exhaust system that doesnt restrict flow, half of us would have it by now. The other half would still be rocking 3" straight pipes on NA. Your best bet is to live with the noise, earplugs, louder music and go down to circuit sports and get you a resonated axleback today!
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 07-18-2018, 08:33 PM   #20
NRXRaptor
it doesn't matter what you say: people will still say that resonators make things more quiet. its like arguing with a flat earther or any conspiracy theorist
op, your axleback doesn't exist. if you want a quiet exhaust, use the stock one. if you want a quiet aftermarket one, I hear invidia q300 is very quiet. both of those have mufflers, as mufflers make things quiet. if you simply want bigger exhaust tips, ask and see if a muffler shop will fab one up for you
NRXRaptor is offline   Reply With Quote
The Following 2 Users Say Thank You to NRXRaptor For This Useful Post:
G-Man (07-19-2018), humfrz (07-18-2018)
Old 07-18-2018, 09:07 PM   #21
humfrz
I'm looking for a quiet catback, or better an axle back, in 60mm with just resonators and no mufflers.
Do you know if this exists?
Welp, there is your original post.
Here is a quote from the reference you posted:
"For those who are thinking about just running resonators for their setup, keep in mind that it’s virtually the equivalent to straight-piping your exhaust. Resonators will remove some of the raspy, ping-y noise from your exhaust, but the volume will virtually be the same – ear-piercingly loud. If that’s what you’re going for, then great! If not, plan on picking up an appropriate set of mufflers to accompany your resonators".
Your call.
humfrz
G-Man (07-19-2018)
Old 07-18-2018, 10:15 PM   #22
monkeybike
Drives: 86
Ignoring terminology, is this what you are looking for?
https://www.hks-power.co.jp/en/produ...ffler/db/15580
monkeybike is offline   Reply With Quote
Old 07-19-2018, 01:24 AM   #23
gpvecchi
gpvecchi's Avatar
Really, direct exhaust are not necessary more noisy than cambers ones. As I said, Supersprint is usually quiet as stock, or even more. I used IE Scorpion (UK) exhaust that was louder even if it had chambers...
This is an Aros exhaust (Italian) for BRZ. I’s straight and really quiet.
Old 07-19-2018, 03:47 AM   #24
humfrz
So, it looks like you found your exhaust yourself -
humfrz
Old 07-19-2018, 07:12 AM   #25
gpvecchi
gpvecchi's Avatar
Nope... 63 mm... :-(
Old 07-19-2018, 07:49 AM   #26
15limited
15limited's Avatar
I hope the only exhaust you can find for any car forever only comes in 63mm.
The Following 2 Users Say Thank You to 15limited For This Useful Post:
FRSBRZGT86FAN (07-20-2018), Laika (07-19-2018)
Old 07-19-2018, 09:39 AM   #27
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Supersprint said once that there were NO GAINS with their axleback or even catback. So, what's the point to focus in this area? Only if sound matters ...
Old 07-19-2018, 10:21 AM   #28
fika84
fika84's Avatar
And they too have mufflers... They call them silencers... we call them mufflers.. http://www.differencebetween.net/obj...r-and-exhaust/
https://arosmarmitte.it/wp-content/u...BARU-BRZ_3.jpg
fika84 is offline   Reply With Quote
Racism and igorance still exists in America? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 25 03-09-2011 02:37 PM
