Old 07-18-2018, 01:02 AM   #15
strat61caster
strat61caster's Avatar
Originally Posted by AxisPower View Post
I was just trying to make the point that the rear lower control arm, which I posted a picture of, doesn't have issues with loosening up like the toe arms because it essentially has two clamps vs the toe arm which only has one.
Having two places where a joint can slip is generally considered less secure than one. Theoretically with the toe arm design with a locking feature on each end you only really need one to be secure to prevent the rod from turning on the threads so in OPs case both ends failed to secure the arms adjustment.
ineedyourdiddly
wparsons (07-18-2018)
Old 07-18-2018, 07:46 AM   #16
wparsons
wparsons's Avatar
The toe arm has two clamps as well... if you compare it to the LCA, the black barrel of the toe arm is the same part as the threaded rod with the nut on it between the arm and the rod end. Instead of clamping into the arm, it clamps to the other rod end. Same effect though, and like someone else mentioned, for the toe to change both clamps have to be loose enough for the barrel to rotate, in theory you only have to stop one end from rotating to stop coarse adjustments from happening. They run two so that the movement of the rod end at the other end can't cause a tiny change in toe.
flickr
Old 07-18-2018, 10:03 PM   #17
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Only one clamp was loose and the amount the end can turn on its own is more than enough to get some good toe "adjustment".
Sleepless is offline   Reply With Quote
Old 07-19-2018, 08:13 PM   #18
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Update:
Only got one session before something in the drivetrain gave up the ghost! But, the steel bolts held the toe link clamps, yay
Also got a msg from SPL saying they'll replace the links with pretested links if the problem re-occurs. Nice.
Next test will be on Z214 slicks (and fixed drive train).
The Following User Says Thank You to Sleepless For This Useful Post:
CSG Mike (07-19-2018)
Old 07-19-2018, 09:32 PM   #19
Originally Posted by Sleepless View Post
Update:
Good news, and bad news
What part failed?
Old 07-20-2018, 04:56 PM   #20
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
What part failed?
Left axle. Not bad for 4+ years of tracking the car hard with an SC. Should I upgrade or stick with stock?
Old 07-20-2018, 09:17 PM   #21
Upgrade. Sticky tires will destroy axles. I've already broken one.
WTB- 1 or 2 OEM rear end links solort Want-To-Buy Requests 3 08-18-2017 05:32 AM
FS: Brand New Racer X Billet Rear LCAs, Rear Toe Links, and Front Tie Rod Ends EGOBRZ Brakes, Suspension, Chassis 4 07-12-2017 12:12 PM
Adjustable End Links (Rear) digital_assassin Brakes, Suspension, Chassis 2 09-26-2015 04:43 PM
FS: Rear Toe Links, OEM Fog Lights FRS2000 Brakes, Suspension, Chassis 3 11-14-2014 08:04 AM
Rear Toe Links? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-05-2012 05:29 PM
