Old 07-08-2018, 07:54 AM   #15
letsteyr
Drives: GT86 turbo FA20DIT
I m in the center (Clermont Ferrand).
I ll find a solution for tuning it.
About logging, ecuedit can provide logging buy i m hesitating because logging BRZ or FA20DIT are two separates licences. So if i buy brz and see i can do nothing to tune the fa20dit engine it ll be lost.
letsteyr is offline   Reply With Quote
Old 07-26-2018, 03:48 PM   #16
letsteyr
Hi! some update (not good). I"ve contacted many standalone manufacturers like haltec, simtek, motec.
Motec might be the only one who could help me but not so easy. Here are their answer:
"The Toyota 86 Plug in kit is designed to work with the FA20D engine. This engine has a number of differences with the FA20DIT engine, the main one being that the D engine uses a DI Amplifier box to drive the DI injectors and HPFP, whereas on the DIT engine, these are directly controlled by the ECU (which also uses a different loom connector). You would need to use one of our M14x M1 ECU's (dependent on injector type) to control the engine but not the rest of the vehicle. We are investigating the development of a Toyota 86 DI Engine Swap Package that will allow for the use of these engines in the 86 range, withcomplete vehicle integration."
"The standard Toyota 86 Package is unable to be used with the FA20D engine as the Reference Mode is different in the two engines, and this cannot be changed in the Toyota 86 Package."
So, to to summarize:
solution1: if i take the PnP GT86 motec ECM, it's impossible to deal with the FA20DIT synchonisation patterns. I don't understand why Motec can't give me the setup of the FA20DIT. So no way
solution2: if i take the M14 motec ECM
- i have to put the FA20DIT intake Wiring (i got it)
- i must remove Port Injectors (ok)
- i must remove GT86 DI box (ok)
BUT i won't be able to make the dashboard and other systems work properly
The Following 3 Users Say Thank You to letsteyr For This Useful Post:
CSG Mike (08-09-2018), Teseo (08-16-2018), tirespin782 (07-27-2018)
Old 08-10-2018, 10:29 AM   #17
Turbowned
Turbowned's Avatar
This has me wondering if it would not be easier to just take the bare FA20DIT block and utilize everything external from the 86/BRZ, including cylinder heads if necessary. It seems like you would need standalone ECU either way, but you would get the simplicity of maintaining most of the factory equipment save for the exhaust manifold and perhaps a few small components here and there. Or perhaps that would not work due to differences in the engines I am not accounting for?
The Following User Says Thank You to Turbowned For This Useful Post:
Teseo (08-16-2018)
Old 08-10-2018, 11:04 AM   #18
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This has been tried in the past by an Austrian team. They finished everything in the development car, but never went in production because they couldn't get a TUV approval. Details here:
http://www.ft86club.com/forums/showthread.php?t=79549
GT86 transmission swap from the WRX STI sman Engine Swaps 1 10-17-2016 08:45 AM
Toyota left a nice surprise if you're doing a Toyota motor swap.. Manji Engine Swaps 15 01-07-2015 01:48 AM
My GT86 headlights swap Drull Cosmetic Modification (Interior/Exterior/Lighting) 0 11-24-2014 09:46 AM
FA20DIT parts glorydays Forced Induction 8 03-14-2014 05:03 PM
