Old 06-29-2018, 09:58 PM   #15
ermax
ermax's Avatar
Originally Posted by Geex View Post
they said that couldn't be the issue that caused it because it was about 8,000 miles ago (And has never leaked again).
Which is just BS. If they got carried away with the packing material it can end up in oil galleries and restrict oil flow.
Old 06-30-2018, 02:51 PM   #16
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thanks for all the replies !
I called Toyota and they are insisting that the issue was due to oil starvation and that they wont cover it.
Show them all the threads about 2013s and spun rod bearings here...plus I am sure there are documented cases on the nhtsa website as well:
https://www.nhtsa.gov/vehicle/2013/SCION/FR-S
Old 06-30-2018, 03:05 PM   #17
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
worst comes to worst, get a used engine which will run you roughly $2.7k + labor. I know it sucks but it is what it is. hopefully Toyota will come through since your warranty is only a few days past due.
shaynek is offline   Reply With Quote
Old 06-30-2018, 06:20 PM   #18
Geex
Yep, already got a used engine from a 2014 with 39k miles on it for $2,660.
Geex is offline   Reply With Quote
Old 07-01-2018, 01:11 AM   #19
sato
sato's Avatar
Drives: Dodge Patitas
Have you followed up with higher level Toyota reps, HQ?
Sent from my Pixel 2 using Tapatalk
Old 07-01-2018, 03:57 PM   #20
Geex
Honestly, I just gave up. Pulling the engine tomorrow.
engine, failure, rodknock, spunbearing, toyota
Engine failure! mackeye Engine, Exhaust, Transmission 24 01-29-2018 11:48 PM
Engine Failure (Bearing Rod 2) Incursion Issues | Warranty | Recalls / TSB 59 11-27-2014 02:17 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
