Old 07-09-2018, 01:48 AM   #15
Harey
Drives: 2013 Toyota 86
Originally Posted by smg1138 View Post
That's what I did, but they still slipped. I used the OEM 14mm bolt on top and the SPC lobed camber bolt on bottom. Not really sure why they slipped because I gave the alignment tech the torque specs for both bolts.
But isnt using the lower OEM 14mm bolt in the top spot still sacrificing strength as the OEM top bolt is thicker (~16mm)?
Harey is offline   Reply With Quote
Old 07-09-2018, 12:58 PM   #16
mabviper
Drives: WRB BRZ
Hmm, I installed an SPC camber bolt on the bottom mount. After I got an alignment, -3 deg, I noticed that the right front wheel is a bit more hidden when compared to the left front wheel. When I took the wheels off, I noticed that the right wheel, the SPC tab was actually pointing inwards while the left wheel had it slightly pointed outwards-down.
Even though the camber is the same, the SPC bolt can push the whole wheel inwards or outwards while the slotted mount will compensate.
I have heard a rather large clunk when going over really sharp, huge bumps (on straight roads) on the right side, the side with the wheel that's more inwards. The left side has no issues. I thought it was the wheel hitting the spring but I'll look into the end link as well. I also ordered 25mm wheel adapters to see if it helps.
This only happens on OEM wheels and not my 17x8 +35 720form wheel.
mabviper is offline   Reply With Quote
Old 07-09-2018, 08:53 PM   #17
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Yeah that makes sense. After I installed them the bottom of the shock started hitting the endlinks near full lock. Think the SPC bolts must have moved the shock body more inside. I'm not a big fan of the design so I'm just going to stick with the OEM 14mm bolts on top and bottom until I can get camber plates.
smg1138 is offline   Reply With Quote
WTB: Camber plates for ST coilovers Stealthy Want-To-Buy Requests 1 04-21-2016 07:57 PM
*BRZ Part Out* RCE T2 coilovers w/HVT camber plates xDanger_208x Brakes, Suspension, Chassis 3 04-02-2015 06:53 PM
FS BC BR Coilovers & Oni Camber Plates SLICVIC Brakes, Suspension, Chassis 0 03-01-2015 02:10 PM
FS: KW V3 Coilovers w/ Vorschlag Camber Plates rever5e Brakes, Suspension, Chassis 10 12-30-2014 06:24 PM
FS: Coilovers W/ Camber Plates $575 Amir Ghadiri Brakes, Suspension, Chassis 8 03-11-2014 02:22 AM
