Old 06-19-2018, 05:36 PM   #15
100% good. No worries at all.
Old 06-19-2018, 05:47 PM   #16
highway7
Drives: FRS 2013
It's most likely from the car being driven on dirt roads in the past, driven near beaches, on sand, or even contamination on city roads and highways. Basically what has happened is some sort of contaminant is caught in between the pad and rotor, or a pebble had wedged itself into the bottom of where the pad meets the rotor and when the car drives forward, it marked the rotor.
What you can do is take the pads off, clean the rotor and brake pad surface with brake cleaner, relube and reinstall, and hopefully in a few thousand KM the wear evens out. Otherwise your only other option is buying new pads and rotors.
However, this is only cosmetic and your braking should not be affected.
highway7 is offline   Reply With Quote
Old 06-19-2018, 07:00 PM   #17
humfrz
Originally Posted by brosifSmith View Post
I dunno old guys can move pretty fast when they're determined! for a short moment... as in.. to hit someone.
Yep, especially as in backing up a car.
Just ask ol @Tcoat.
humfrz
Old 06-19-2018, 07:06 PM   #18
Just ask ol @Tcoat.
humfrz
Yep you can do that really fast. Regardless if what is back there!
humfrz (06-19-2018)
Old 06-19-2018, 07:28 PM   #19
humfrz
Like they said, back-in-day - "jet pilots don't use rear view mirrors".
humfrz
Old 06-19-2018, 07:49 PM   #20
humfrz
Not true.
Old 06-19-2018, 08:02 PM   #21
humfrz
Not true.
I'm talken waaaay back-in-the-day.
humfrz
Tcoat (06-19-2018)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
