Old 06-02-2018, 02:28 AM   #15
FunnyGopher
Drives: 2015 BRZ Limited
Originally Posted by 86TOYO2k17 View Post
Nice setup, curious if you have any before/after 0-60 or 1/4mile after the grams throttle body?
Sadly, I do not have before or after anythings for the throttle body. I have dynographs before and after the ACE setup though, but the before includes the throttle body and CAI.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following User Says Thank You to FunnyGopher For This Useful Post:
jayliu.jiayu@gamil.com (06-18-2018)
Old 06-18-2018, 07:56 AM   #16
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
Originally Posted by tyler_win_photo View Post
You're going to need to go catless to reach at least 20hp gain after a tune.
thx for the advance buddy
i think i will for for jdl catted equal header with motive cat less over and front pipe
with afe intake
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 06-18-2018, 08:22 AM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
jailiu.jiayu: better other way around for more gains. Catless header and catted frontpipe. Primary cat in headers hurt performance more due it's placement near cylinders, and also need to put it there hurts header design, striking out more efficient. One can also save some $ with catless header and eg. "free" stock catted frontpipe.
Old 06-18-2018, 11:03 AM   #18
i cant ignore those sign on dash........
will do more research
and i need find some local shop first for tuning too
Old 06-18-2018, 12:02 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
jayliu.jiayu: Signs on dash? As in check engine light? But you also wrote that you plan to get ecu tune aswell. Disable cat readiness checks in it (in most ecu tunes it already is done), should do. Aftermarket catted header btw is not sure way to never throw cat related CEL code. So most probably you'll have those checks disabled in tune for it anyway .. and if so .. why not catless header in first place?
Old 06-19-2018, 07:37 AM   #20
that true
personally just wanna give it a try.......
i am a picky guy
Piper Cam Selection bju90 Engine, Exhaust, Transmission 33 09-22-2020 11:47 PM
Piper Camshafts brn12345 Engine, Exhaust, Transmission 120 10-02-2017 11:28 AM
Piper Camshaft.. Walla Walla Engine, Exhaust, Transmission 5 05-12-2017 09:46 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
does it make a difference at all in hp from an invida over piper compared to motiv Anthony7515 Engine, Exhaust, Transmission 3 04-07-2014 11:26 PM
