Old 05-23-2018, 04:51 PM   #15
Sleepyyysam
sleepy
Sleepyyysam's Avatar
Drives: Brz
You mentioned the top plate alignment earlier so I skipped it. A couple people here ran into issues from neglecting that after installing a short shifter. If the previous owner was sloppy, I can imagine a marginal alignment causing trouble after thermal expansion, blah blah...
There's a procedure in the manual which involves feeler gauges but it's kind of overkill. The middle of the gates are easy enough to feel by hand.
Yeah, I'm about two hours into driving on it and not feeling the problems I had before. I'm going to assume it was the plate placement.
Sent from my Pixel XL using Tapatalk
Sleepyyysam is offline   Reply With Quote
Anyone feel like they have a clunky gear change? Haseebali31 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 04-16-2022 02:52 PM
Clunky and hard gear shifts nhuyvan1106 Issues | Warranty | Recalls / TSB 45 08-26-2017 01:52 PM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
