Old 05-22-2018, 09:40 PM   #15
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
Thanks for all the help and suggestions over the last three days. That was a lot of stress and it was driving me nuts. I tightened both pretty tight tonight and all of the noises went away. All is right with the world.
2013 FR-S Asphalt Grey
HKS Hipermax IV GT
Sparco Assetto Gara MGC 17x7.5
Invidia N1 exhaust
Scoob is offline   Reply With Quote
The Following 3 Users Say Thank You to Scoob For This Useful Post:
Alltezza (05-23-2018), humfrz (05-22-2018), venturaII (05-23-2018)
Old 05-22-2018, 10:10 PM   #16
humfrz
Noise can transmit easily so it is not necessarily coming fron where you think. It sounds more creaking that rattling to me but its hard to tell, your video has no video so unsure of speed or steering input.
If it were my car I would get everything gorilla tight that has less than 100ft/lbs rating. The rest i would get a 1/2" breaker and extra gorillabtight them. Like the 2 bolts connecting the strut to the spindle are rated at 180lb/ft if i recall.
Then i would give the top strut bolt a 1/2 second of impact at 3/4 to full beans. Just enough you see the shaft move but don't spin it like a dreidel.
But yea it sounds creaky. How low are you? Did you have this sound before you added camber? You used oem studs or what. Take a 1/2" breaker bar and tighten your lug nuts hard, more than the 89 lb/ft spec. When i put in my ARP studs i set my impact to the 200 lb/ft setting. I didnt wail on it but it takes some force to get them seated.
As a casual DIY I found most of my noises were user error and not bad parts.
Might I suggest a 3/4" drive socket set for your "light" tightening work ……
humfrz
ZionsWrath (05-23-2018)
Old 05-23-2018, 01:43 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
humfrz
Lol i have it and a 3/4" breaker bar. For axle nuts i swear >_^
The Following User Says Thank You to ZionsWrath For This Useful Post:
humfrz (05-23-2018)
Suspension noise identified, need help diagnosing a fix norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-17-2018 03:48 AM
Suspension Loud Noise jdavila Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-15-2017 12:15 PM
Suspension noise? HubertK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-09-2017 08:50 PM
Rear suspension clunking noise. Help ): dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 09-15-2016 03:09 AM
Stock suspension noise lite Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-12-2016 05:55 PM
