#15 |
I have been told by my local 86 group and my STI friends to always go with Motul Gear 300. I want no part in a subjective debate, but just curious if I am missing something? Is Motul too expensive? Not good for our cars? I am about to change my fluids again after doing Motul in both Tranny and Diff about 30k miles ago and am open to suggestions if there is a different consensus on what is best for our cars.
| The Following User Says Thank You to paintdude258 For This Useful Post: | JesseG (11-01-2019) |
#16 | |
The Dictater
Drives: '13 Red Scion FRS
Long answer: On reflection I do think my transmission could be described as crunchy entering every gear, particularly when cold. At the time, I just considered it normal, but I could see how someone could find it annoying. In my experience, amsoil fixed that. It's now smooth with an occasional crunchy shift when "cold", but that's just the nature of the transmission. I use quotes because I haven't driven it in under 70 F temperatures yet. Any winter driving may have a different set of issues. Just to be clear, your transmission is not making grinding sounds right? I'm defining crunchy as it feels like you are crushing a bag of potato chips when entering a gear. Your results may be a bit different of course, but it sounds like the amsoil MT oil will at least be a step in the right direction. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | JesseG (11-01-2019), Spec C Wannabe (05-31-2018) |
#17 | |
The Dictater
#18 | |
Drives: 2017 WRB M/T BRZ
Thanks for your detailed answer. Appreciated it. To answer your question, No I don't have any "grindings" in my transmission. It just feels crunchy going into gears. What I can describe is that I can feel I am moving a gear lever through something that is moving inside. Feels like dragging my stick through the gravels or something. It is not very obvious but it is kind of annoying. Moving the gear lever through the gate is quite sticky and heavy when the transmission is cold. It just make driving the car tiring and worrisome. When cold (my cold means when I first drive the car after let it sit overnight as I live in hot climate morning temp is around 85 degree F) the problem will be worse as sometimes I can feel and even "hear" the crunch for the first few shifts but it will get better and better the longer I drive it. It gets best when I drive it really really hard like when I was running in the race track and that was when my transmission felt SWEET!! How many miles did you have before changing the trans oil? Mine is currently at around 8,000 mile and still on factory fill. |
| The Following User Says Thank You to Spec C Wannabe For This Useful Post: | JesseG (11-01-2019) |
#19 | |
The Dictater
About 35,000 miles on factory fill before I changed it out. |
| The Following User Says Thank You to Spuds For This Useful Post: | JesseG (11-01-2019) |
#20 | |
Drives: 2013 FRS
| The Following User Says Thank You to CoolHandMoss For This Useful Post: | JesseG (11-01-2019) |
#21 | |
Only users lose drugs.
Drives: All the time
That's not to say Gear 300 will immediately make your transmission explode. You could probably use olive oil for a while and get away with it. However, the additives which make the oil GL5 rated also have a detrimental long term effect on the yellow metals used in any transmission designed around GL3/4 oils, which includes ours.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 3 Users Say Thank You to venturaII For This Useful Post: |
#22 | |
Oh Hot Damn!! This just blew my mind with facts.
![]() Thank you! Quote:
#23 |
#24 |
Drives: 2013 FRS
After putting about 1k miles on the car with amsoil in the transmission I will say that the second gear shift loves it. Second gear is almost always smooth at anything but the coolest temperatures. On the other hand, strangely, 5th gear seems to not like it as much. I have to shift to 5th more slowly now or it will grind when it never would before. Though, this could be a result of the transmission mount stiffening insert I installed at the same time. I'm sure the improvement in second gear is due to the amsoil though. In conclusion, I recommend it. I'll probably stick with it long term.
#25 | |
The Dictater
#26 |
Drives: 2016 White Pearl BRZ Premium
Anecdotal chime in - my experience with Amsoil mirrors the OP. The gearbox shifts easier and smoother with their oil in it.
#27 |
The Dictater
Drove it today, and 5th feels the same as other gears to me. I know that I had to get used to the shifter bushing when that went in and had to be more precise with the shifter. Agree with above assessment.
| The Following User Says Thank You to Spuds For This Useful Post: | venturaII (06-08-2018) |
#28 | |
http://www.ft86club.com/forums/showthread.php?t=71030 http://www.ft86club.com/forums/showthread.php?t=118607 At what speed did you have the 5th gear grind? |
| The Following User Says Thank You to Spec C Wannabe For This Useful Post: | Spuds (06-10-2018) |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
| Transmission oil change 2nd time - previously amsoil | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-07-2017 11:47 PM |
| Amsoil Oils Complete Change | BC-Boy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 04-25-2014 01:04 PM |
| Was doing the transmission and diff oils today, when... what is this thing? | Entroper | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 03-11-2013 11:40 PM |
