Old 05-02-2018, 02:24 PM   #15
Originally Posted by 14stu View Post
I've nearly burned my hand trying to check tire pressures immediately after coming off track, so I'm painfully aware of how hot rotors get. But the wheels themselves shouldn't heat up too much (not enough to thermally expand enough to loosen a center cap.).
The thermal camera videos of brake cooling tests show the rotor behind the wheels glowing hot and the wheels in front dark and cool but the scale could be too high to read the wheel temps.
I'll have to take some temperature readings next time, I'm not nearly as sure the wheels don't get that hot anymore. I know they could very quickly because I've changed wheels in between sessions and while the tires were warm the wheels weren't.
Sent from my SM-G935V using Tapatalk
On a stock car, rotor heat conducts to the rotor hat, which then conducts into the knuckle and wheel. After a session, the wheels being a few hundred degrees is not unusual.
This is part of the reason why 2 piece rotors are used; it helps keep the heat in the rotor to dissipate away, rather than conducting out to the knuckle and wheel, which doesn't have as much surface area relative to the mass. That heat can also contribute to wheel bearing failure, and wheel fatigue, in extreme cases.
Old 05-04-2018, 12:00 PM   #16
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
I'm surprised you warped the rotors with stock pads. Did you set the parking brake after coming off track, or hold the brake in pits/paddock for a long time after coming off?
trippinbillies40 is offline   Reply With Quote
Old 05-04-2018, 12:14 PM   #17
jvincent
jvincent's Avatar
The rotors are likely not warped.
What he's probably feeling is the effect of brake pad compound smeared all over the surface of the rotor.
When I melted my OEM pads (lazy, didn't take them off one day) the feeling afterwards was terrible.
Eventually the pad material scraped off and things were fine again.
The Following 3 Users Say Thank You to jvincent For This Useful Post:
strat61caster (05-04-2018), trippinbillies40 (05-04-2018), Ultramaroon (05-04-2018)
Old 05-04-2018, 01:40 PM   #18
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Rotors don't warp. That's almost a myth.
Maybe solid rotor, but ventilated rotors (like all front rotors, and the twins rear) are almost impossible to warp. They will crack before warping.
The feeling of warp rotor is almost always pad material not evenly transfered on the rotors because of overheating, or appliying the brake when stopped, or a craked rotor.
Bad transfer layer can sometimes be corrected by bedding-in or "turning" the rotors.
nico_rsx is offline   Reply With Quote
The Following 3 Users Say Thank You to nico_rsx For This Useful Post:
Hyper4mance2k (05-25-2018), Icecreamtruk (05-04-2018), rice_classic (05-24-2018)
Old 05-04-2018, 01:50 PM   #19
Icecreamtruk
Drives: Track preped NA FRS
In my limited experience (some 4 years doing HPDE and time attack, around 30 days total), I have never had a warped rotor, but I had cracked some and its as you say, they feel like warped (vibration on the pedal). Even with uneven/bad transfer layers on the rotors, it didnt really make much of a difference to feel (it did to braking distance on the other hand).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
nico_rsx (05-05-2018)
Old 05-04-2018, 02:10 PM   #20
Almost a myth is correct. Pretty hard to warp a car rotor since it has to be heated up extensively and very quickly. Even the hardest track braking doesn't do it fast enough so as you said they crack instead.
We make pick up truck (and some car) rotors where I work and every couple of months we get a set of badly warped vented rotors sent back for warranty investigation. They are always the front and the dealer documents usually start with "customer was going down a large hill pulling a heavily loaded trailer and noticed a pulsing in the brakes right after". Conditions like that can warp them pretty badly.
nico_rsx (05-05-2018), nikitopo (07-28-2018)
Old 05-04-2018, 05:21 PM   #21
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Originally Posted by mkodama View Post
The brake pads and CENTERCAPS.
The pads overheat and give a warped rotor feeling bad enough to end a track day; a little surprising on stock Michelin Primacy HP tires. The real surprise is the front center caps fell out but not the rears; my theory is the front brakes make enough heat to relax the centercap retaining tabs.
This was track day #6 in the BRZ at Laguna Seca and the problems only started showing up when my instructor had me braking harder.
Time to look into new pads!
I am amazed you got SIX days out of stock pads. If you were hard on them, they'd be smeared in a day. I run Carbotech XP10 pads and have no issues with my brakes at all.
The wheels get very, very hot, but are most definitely not deforming at the hub so much that the caps fall out, as someone else suggested. The tabs get soft when they are riding in a 200+ degree wheel.
One thing I did preemptively, based on experience with my WRX, is replace the stock lug nuts. I would get stripped nuts every time I hit the track with that car. Yes, I own a torque wrench. No, I did not cross thread them. They are of terrible quality.
My Primacys are working well and have several weekends on them. Coming to the end of that road, though...
Oil cooler goes on this week, as I would like to see temps stay well below the 270 max I am seeing now.
I really don't expect anything else to fail at this point. I just want 17x9 wheels and stickier rubber
bmxr is offline   Reply With Quote
Old 05-16-2018, 02:37 AM   #22
mkodama
86 Challenge
Drives: 2017 BRZ
Subaru replaced the center caps free of charge.
-Called dealership parts department, ~$30 for Subaru caps and $50 special order for the STi caps, this is more than I want to pay on plastic caps that pop out.
-First local dealership service advisor I talked to told me centercaps are not covered by warranty, I said “Oh, so it’s normal for these to fall off?” He backtracked a bit and then elaborated that “the warranty item is no longer present.”
-I emailed Subaru NA and they said to schedule an inspection of the matter at that dealership and provided an SR#. I let them know what date the inspection was scheduled.
-Dropped my car off at the dealership in the morning and picked it up at lunch, they asked for the SR#, this second service advisor was super friendly, and sent me on my way with two new centercaps and a receipt for $0.00
-Subaru NA gave me a follow up call an hour later and I let them know I was happy and told them “Thanks!”
Really liking Subaru at this point.
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
CSG Mike (07-27-2018)
Old 07-27-2018, 10:24 PM   #23
Turbowned
Turbowned's Avatar
Just wanted to chime in on this. Yes, racing pads are a MUST. I have not run a lapping day on stock pads but I can say the four lapping days I've run with Winmax W5's has been incredible. I just did a full day covering approximately 180 miles at Pueblo Motorsports Park today. Between the pads, Castrol SRF React brake fluid and Potenza RE-71R tires, I can stand on the brakes all day long with zero fade. I'm pretty sure the heat has discolored my calipers already, but ironically my center caps are still snug as a bug in a rug (maybe I'm pushing my luck and should remove them).
On the subject of tires, a lot of people say the RE-71R is only good for a quick sprint or one good hot lap before they fall off and I don't know what they're talking about. I was lapping consistently all day, the only variation in time due to driver error. They started to fall off only when I wore the outer shoulder off because I don't have enough front camber yet. I'm on my second set only because I was moving cross country and didn't want to drive 2,000 miles on my first set which is still at ~4/32nds; I'll get another event or three out of them I suspect!
I broke a wheel stud this morning from said terrible lug nuts and am going to break another one tomorrow when I go to swap my pads. Any recommendations on a good set of lug nuts? I was considering getting ARP extended studs eventually, too. Friend of mine has broken his fair share from swapping wheels so many times at the track, too. I was 90% sure I didn't cross thread mine, either!
Oil cooler, yes. My temps are creeping just above 270 and that seems like danger zone territory to me; the temp has stayed consistent with zero power loss or warning signs, thankfully. I run Pennzoil Platinum Euro 5W30 in case anyone cares.
The Following User Says Thank You to Turbowned For This Useful Post:
Old 07-27-2018, 11:35 PM   #24
I'll gladly demonstrate for you if you come out to California!
Check out https://www.counterspacegarage.com/c...ugnuts-m12x125 They're made with SCM435, which is a chromoly alloy specifically designed for shafts, gears, and screws exposed to high stress high temp.
Turbowned (07-27-2018)
Old 07-28-2018, 12:44 AM   #25
whataboutbob
AutoX-10/10ths every run
After an autocross competition day with 4 60 second runs my wheels were hot enough that I couldn't swap them right after my run group without waiting for them to cool off. This was on stock callipers and Winmax W3 pads.
Build thread:Here
Old 07-29-2018, 05:04 AM   #26
mkodama
86 Challenge
Drives: 2017 BRZ
New vs tracked center caps:
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
Looking for Brz OEM 17 wheel for performance package khcho19 Want-To-Buy Requests 1 04-27-2018 11:09 AM
WTB: BRZ Performance Package wheels funwheeldrive Want-To-Buy Requests 2 01-14-2018 02:29 PM
Performance Package 86? masahiro Scion FR-S / Toyota 86 GT86 General Forum 10 11-01-2017 05:29 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
