#15 |
You guys need to log afr, commanded afr , maf, manifold pressure, throttle , rpm , pprt amd direct injector pulse widths. Stft, ltft so you can see ehats going on.
High positive ltft at low rpm indicates intake or exhaust leaks, cracked header or similar High negitive trims, often dirty maf sensor or oil on maf sensor Afr cycling between very rich amd very lean like 11 to 15 fairly quickly at idle can be failed 02 sensor But you need to log and confirm |
#16 |
Drives: RHD Gt86
Same issue here, did u figure it out?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#17 |
Drives: JDL Turbo BRZ
#18 | |
Drives: 2013 frs raven
Everything stays normal ish at cruising speed |
#19 |
Drives: 2013 FR-S Series 10
I had a week or so where my fuel trims would go to -29%, car ran fine otherwise.
I pulled the MAF to clean it but it was spotless and bone dry... didn't do anything to it. i reinstalled the sensor and like magic my trims went back to +0-3% Hasn't happened since.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#20 | |
So I cleaned the air filter, maf, map and TB all at one shot and it seems to have cleared up. Nothing looked perticularly dirty, but the issue seems to have gone away. ¯\_(ツ)_/¯ |
#21 | |
I was turbocharged too. AFR was super rich because spark wasn't firing due to bad coil pack. |
#22 | |
Were you having any notable running issues other than the super negative fuel trims? Like if you didn't have the ability to datalog would you have had any reason to assume there was an issue? |
#23 |
Drives: frs
So could be 2 factor:
Coil packs MAF/intake related I did the maf cleaning with CRC maf cleaner and ran ok for a while. Then started to have that bogging on/off throttle in lower RPM's with negative LT Fuel trim (-17.98%). Coil packs swap next? |
| Tags |
| bogging, bucking, high fuel trim, high pitch noise |
| Diagnosing high positive LTFT | Tectoniic | Software Tuning | 22 | 05-03-2022 02:24 AM |
| Is it normal for STFT and LTFT to always be 5% above? | pcguru2000 | Issues | Warranty | Recalls / TSB | 3 | 04-13-2018 08:36 PM |
| High Negative LTFT on N/A BRZ causing idling issues | paintdude258 | Software Tuning | 57 | 03-26-2017 08:14 AM |
| high ltft while running e85 with oft | flat4_86 | Software Tuning | 4 | 01-22-2017 12:47 AM |
| high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 10:27 PM |
