| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: Legacy
I strongly recommend the Pilot Sport 4 tires which are dynamite and I think cure a lot of ills the BRZ may have. Last edited by Rai-zero; 04-30-2018 at 09:29 AM. |
| The Following User Says Thank You to Rai-zero For This Useful Post: | rvoll (04-30-2018) |
#16 | |
Does electronic aids help or ...
#17 | |
Drives: '12 C63 P31, '23 GRC
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post: | Ganthrithor (05-01-2018), Tcoat (04-30-2018) |
#18 |
The torque vectoring in the wife's Impreza is well done and I am a fan. That is in a AWD hatch though. Would not want in a RWD coupe.
#19 |
Hey Guys...
Thanks for all the inputs Regards to my "floating manner" experience, looks like hydroplaning is the most likely cause. (Both times it happen, i was on wet surface) Yep, i'm on the infamous Prius tyre. I'm considering to change to Mic PS4/Falken 452, If i am only changing 2pc for a start, should the new tyre go to the front or rear ? Will it be too much for the stock rim if i go for 225 width tyre ? Understand 7J rim accept 205-215 tyre. Regards to the absence of the Torque Vectoring on the twins, iirc, the electronic will help you 'steer'. I suppose the electronic do that by vectoring the torque btw the Rear/Right & Rear/Left wheel ? Or it will only brake the Front wheels to achieve that ? Cheers !! |
#20 |
A.K.A. Starlord
Drives: 2015 Series.Blue
It uses the brakes at all four corners to do this. The diff itself does not have the ability to direct torque apart from the standard diff-stuff it does.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#21 |
I run 225/45R17 on my IS300 which also has a 7in rim and it’s just fine. As for which place to put the new tires, although not as fun I’d put the ones with the most grip on the rear. The car is already tail happy, no need to make it even more tail happy. I had a set of Dunlop Z2 all the way around my IS300 once and then need to replace two so I ended up with two Z2 Star Spec on the front. I didn’t expect the Z2SS to have that much more grip than the Z2. The car was really tail happy but I left it as is and just drove appropriately. Not sure I would recommend this to a stranger though.
As for the VSC. Although intrusive it does a damn good job. I leave it on in the rain and it’s saved me a few times when these crap tires let go even when driving like my grandmother. |
#22 |
#23 |
Drives: 2015 Subaru BRZ Limited DGM
Exactly. And if the VSC light isn't flashing at you in the middle of the dash the system isn't activating at all.
#24 |
Drives: '13 BRZ, '06 997, Other Things(TM)
The aids can be annoying if you're driving hard intentionally (the fake "torque vectoring" using brakes is the one I usually notice if I'm cornering hard on a bumpy surface... it seems to be a bit more aggressive about interventions than it needs to be), but they're not gonna wreck your car. Leave them on. Sport mode is fine for everyday driving. If you leave everything on, sometimes the computer doesn't like accelerating into a turn from a stop sign or junction when there's any kind of loose surface (bit of gravel on road, dust pile, etc), but sport mode is enough to stop those annoying interferences.
Also if you live somewhere with rain, get the fuck off the Prius tyres. They're fine on dry roads but driving in rain with them-- even with plenty of tread left-- is like driving on snow. |
#25 | |
Proud of BOXER
Drives: Subaru Boxer
In the LFA video, I notice the road surface changes from asphalt to concrete right before/as he spins out. Does the surface change or slight lip from one surface to another have anything to do with what happened?
#26 | |
Okay so the LFA came with S001's. Seems kind of under tired for that car. |
#27 | ||
Proud of BOXER
Hard to say exactly what happened, or what the cause of the crash was, but one things for sure: he should not have been driving/accelerating like that on a crowded public road.
#28 |
Drives: 2014 DGM BRZ
On numerous occasions the electronic aids have prevented me from losing the back end, mostly during times of slippery/icy road conditions on the highway where I deliberately (and indeliberately) try to accelerate too fast.
In my 1st or 2nd year of ownership, I met a freak snowstorm on the highway (while running the prius tires). I had the electronic aids off and lost control before I even had the chance to react - ended up in the ditch. It was a stupid thing to have the aids off in those conditions and will never do it again. On the other hand, when I had the chance to take my car on an ice driving course on a frozen lake, I found it much easier to predict the dynamics of car, as well as apply driving output (steering and countersteering) when the aids were completely off. Just my 2 cents! |
| The Following User Says Thank You to Brooklyn For This Useful Post: | Tcoat (05-04-2018) |
| Can driver aids work after an engine swap? | @Art_Mighty | Engine Swaps | 9 | 11-29-2016 08:43 AM |
| Is there a way to turn all the aids off w/o doing the pedal dance? | D K | Tracking / Autocross / HPDE / Drifting | 4 | 07-07-2014 09:16 AM |
| Disabled the driving aids. Here are my impressions. | diss7 | Scion FR-S / Toyota 86 GT86 General Forum | 284 | 01-10-2014 07:36 PM |
| Electronic Driving Aids | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 03-07-2013 07:45 PM |
