#15 |
The Dictater
Drives: '13 Red Scion FRS
Humfrz and 'Bubba'...
#16 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
OEM Tokyo Roki (Subaru 15208AA130)
Don't know what the new style OEM ones are like internally so I won't switch. My only other choices if I can't get those are Purelator PureOne or Wix |
#17 |
Mostly oem. One thing I've noticed though, and I'm not sure it's been mentioned, the Toyota and Subaru filters are different.
#18 |
StreetKart
Drives: 2014 Scion FR-S Monogram
Why tho? what about that particular oem filter makes you want to use it? Materials? Pressure relief setting? because JDM?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#19 |
StreetKart
From what I understand the Toyota filters were just the updated subaru design. the original subaru filters are no longer available. but again, no one can tell me why one is better than the other
#20 | |
When people have cut them open the fins on the Tokyo Roki were much tighter compared to others and appeared to have more media to filter particles. PureOne and Wix were close. Fram, cheap Purelator, etc had less fins so less media to filter, cheap cardboard endcaps, etc. |
#21 | |
#22 |
Driver
Drives: 2013 Whiteout FRS
used K&N but always go back to OEM subaru. Cant beat OEM quality. most aftermarket just charge more for the pretty colour of the filter.
#23 | |
I figured particals are so small its not like something large will clog something up in between fins |
| The Following User Says Thank You to finch1750 For This Useful Post: | JazzleSAURUS (03-29-2018) |
#24 | |
Proud of BOXER
Drives: Subaru Boxer
Source?
#25 | |
Can't remember much about the other ones.. except that FRAM makes crap filters. Even on their best filters (Ultra Synthetic) they still use the same crappy base plates & bypass valve as their regular cheap filters. I think someone on this forum once stripped the threading where you screw in the oil filter because the threading on the Fram filter was wrong too. |
#26 |
Drives: 2014 Whiteout Monogram 6MT FR-S
OEM generally because that’s what was designed for the car.
TRD “just because” and I like the red... wulfstan |
#27 |
Drives: 2020 STI Limited
OEM on the BRZ, but I've also used M1 and Bosch filters on my other vehicles/motorcycles as well since they are usually pretty highly rated. Just stay away from Fram.
#28 |
Drives: 15 BRZ LTD, 05 FXT
With filters, the more higher quality media the better, up until the point where it's excessively robbing power. This can be achieved through more, deeper pleats to increase surface area, (filters a higher volume with a potentially denser/tighter media.)
The OEM Subaru Black Tokyo Roki filters are excellent quality and cheap to buy 6 at a time on Amazon so that's what I roll with. On my EJ powered cars, I run OEM Mazda RX8 filters, which are also made by Tokyo Roki and have all of the original STi specifications of the larger, higher quality filter. I've had the lower quality filters have media blowouts causing weird oil pressure events on built motor cars with high flow pumps. This has never occurred on the same cars with the Tokyo Roki manufactured filters. (This occured with a current EJ Subaru blue, fram, and lower end Purolator, (not the PureOne filters.) Edit: I have a huge pipe cutter that I cut open every oil filter I take off a car with to inspect for obscurities. A quick visual for damaged media, a failed bypass valve, excessive glitter on the media etc can tell me the oil or filter isn't doing it's job and a Blackstone test is in order, or the engine is about to go kablooey.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tristor (03-30-2018) |
| TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development | hirollaz | Engine, Exhaust, Bolt-Ons | 0 | 03-15-2017 02:46 AM |
| Cusco Oil Filter or Blitz Oil Filter | Mr.Impreza | CANADA | 6 | 10-11-2014 07:08 AM |
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
