Old 03-08-2018, 08:49 PM   #15
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
@IA_FRS
For looks, it depends on your taste-- 245 wouldn't be too bad on an 8 inch wheel [imo].
see thread for Hankook RS3 in 245/40 on 17x8 RPF1: http://www.ft86club.com/forums/showthread.php?t=10257
edit: and for comparison, see post 149 [in the same thread] for Michelin PSS 225/45/17 on 17x8 RPF1: http://www.ft86club.com/forums/showp...&postcount=149
note that different tire brands/models will run wider than others
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 03-09-2018, 09:10 AM   #16
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by IA_FRS View Post
Thanks for the replies, from what I read here the consensus seems to be the 225/45. And consensus gets to be consensus for a reason right? I think that's the way I'm going to go.
Be aware that 225/45 is also taller overall than 245/40. Your gearing is consequently also taller as a result, so the car theoretically might feel a little less punchy in a straight line. 245/40 closest matches the rolling diameter of the stock 215/45s better.
205/55-16 834 revs/mi
225/50-16 834
215/45-17 844
225/40-17 831
245/40-17 841
Is it enough to be a concern? Dunno; probably not. I run a very light 225/50-16 setup, which are also taller than stock, and I feel there's far more to be gained by by the change to lightweight wheels and a good tire, than worrying about small changes in height/gearing.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Tire size advice Lost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-28-2016 06:42 PM
Tire size... need advice... stokeless Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-12-2015 02:57 PM
tire size advice needed marcom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-08-2015 03:45 PM
Need advice on tire size for track duty?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 02-05-2013 07:50 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
