Old 03-02-2018, 06:38 PM   #15
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by Teseo View Post
Mate, thats is a overkill. If you use 0w-20 you are good, i would be worried about battery
Amsoil says 25k (15k for the filter) or one year. So far I've only put on 1k in 9 months, so I'll be going with the time. Haha.
I have a NoCo Genius battery charger that I throw on every other week just so the battery doesn't go flat.
Old 03-02-2018, 07:57 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I've had good UOAs with 8-9k intervals from a few years ago. Don't think I have them anymore though.
Using both Mobil1 and Castrol 0w-20 and OEM Tokyo Roki filters
8RZ (03-06-2018)
Old 03-02-2018, 10:52 PM   #17
humfrz
Ahhhh.........yes, I often think how simple it was in the old days. I'd change the oil in the spring and put in 30 weight and then change the oil in the fall and put in 20 weight and it didn't matter what brand.
humfrz
chaoskaze (03-23-2018)
Old 03-03-2018, 10:40 AM   #18
RickyBobby
Drives: 2013 Firestorm FR-S AT
I use full synthetic in all my vehicles. My Ford Escape makes it easy, since I'm too old to remember and too lazy to write it down, and tells me when to change the oil, which is usually around 9,800 miles.
Not going to debate this, plenty of oil threads here for that, I change the oil on the FR-S once a year, or ~every 10,000 miles. I checked the manual and there is no "Hey DA time to change the oil indicator" on the FR-S. https://www.toyota.com/t3Portal/docu...f/OM1372QG.pdf
RickyBobby is offline   Reply With Quote
Old 03-06-2018, 11:56 AM   #19
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm thankful for this, one less dummy light on the dash to worry about lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-06-2018, 01:39 PM   #20
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
WOW and here I am beating my self up for only changing my oil once in the last year.. (I only put 4k miles on the car in that time too)
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
Clipdat (03-07-2018)
Old 03-06-2018, 09:57 PM   #21
humfrz
Don't want to be ah wearen that puppy out too soon .....
humfrz
JeremyR (03-07-2018)
Old 03-08-2018, 10:41 AM   #22
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've been doing 10,000 mile intervals since I bought the car (apart from the first oil change done at 6,000 miles when I switched it out for AMSOIL) and I've been doing Blackstone Labs analyses with every oil change as well. It's not uncommon for me to run an entire season of autocross on the same oil change (that means at least 10 events, towing a trailer to/from events, and this is also my daily driver here in Chicago, so a lot of "city use" which is harder on oil, not to mention use throughout winter as well.
No issues thus far
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Teseo (03-08-2018)
Old 03-08-2018, 03:07 PM   #23
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by mav1178 View Post
Oil additive in Mobil 1.
My ENEOS Sustina for comparison.
http://www.ft86club.com/forums/showp...5&postcount=77
I wanted to stretch mine to over 10k as well, but I simply was not putting enough "normal" miles on the engine.
Are you changing out the Sustina at 5k intervals?
Old 03-08-2018, 03:09 PM   #24
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I haven't had my car for 2 years now.
The Following User Says Thank You to mav1178 For This Useful Post:
NyC Zn6 (03-08-2018)
Old 03-08-2018, 05:57 PM   #25
bababooey
Drives: BRZ SWP Limited -6MT
why's that? its a slick looking car in avatar, and you're here frequently with useful info.
Old 03-08-2018, 09:49 PM   #26
humfrz
I didn't realize that .....
What kind of fun car are you driving now .... ??
humfrz
Old 03-09-2018, 02:13 AM   #27
Somerandom18
Drives: 2017 manual BRZ
No issues thus far
TBN of 6 at 10k OCI. Damn!
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-09-2018, 10:31 AM   #28
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
I changed to Mobile One at 250 miles, just to clean up the possible manufacturing junk in there. I changed again at 5K miles and will probably change next month when I hit 10K. I need to swap out the gearbox oil with some Redline.
Love Motul 300V in all the motorcycles, but no source for auto version around here.
SCQTT is offline   Reply With Quote
how many miles before first oil change Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 72 10-25-2014 11:35 AM
Just purchased my '13 BRZ with 1,800 miles. Should I change the oil? torqueno Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 10-08-2014 11:55 PM
Oil change at 4100 miles djdrugga24 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2014 03:00 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 01:31 PM
Oil change at 1000 miles. Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 03-08-2013 05:18 PM
