Old 08-05-2018, 05:27 AM   #15
conehead
Drives: RS 2.0
Originally Posted by randyzimmer View Post
Hi. Testing so far has been really positive. There have been two updates to the design since the site's pictures. One thing that's been hard to fix is getting fresh air to the offside pistons on 4/6/8 pot calipers. All I've been able to do is churn the air while moving but sitting in the paddock, even with brushless fans, the fluid temp starts rising and the pedal needs a pump once moving again. What I'm trying to say is that having a slider with all the pistons toward the fresh air seems to be a plus for cooling.
I was actually looking at the lower control arm ducts, so that they could be easily removable to stay legal in SSC. I have seen a similar design used on Focus STs that swap between track and autox duty.
conehead is offline   Reply With Quote
Old 08-05-2018, 02:04 PM   #16
randyzimmer
Drives: 2 Subaru Wagons
Hi. My tester is using High Plains in Denver. I've never been to that track but he says the LCA ducts are doing as well there as the fans have. Our testing of the LCA ducts on an STi on a really tough cooling track have them about equal to the traditional ducts (not available for the BRZ due to space) but not as good as the fans. The LCA ducts are super easy to take on and off, use existing holes in the A arms.
randyzimmer is offline   Reply With Quote
Old 08-05-2018, 10:59 PM   #17
conehead
Drives: RS 2.0
Another noob question: With the suspension getting replaced, is there any significant difference between the twins? Is the FRS lighter, or does the BRZ have any useful options, etc.?
Old 08-05-2018, 11:07 PM   #18
cjd
cjd's Avatar
Drives: 2017 BRZ
I believe the heated seats in the BRZ Limited make it heavier. A little. Worth it for your winter ice racing adventures...
Old 08-06-2018, 04:09 AM   #19
conehead
Drives: RS 2.0
The most critical option here in Phoenix!
The Following User Says Thank You to conehead For This Useful Post:
cjd (08-06-2018)
Old 08-06-2018, 07:37 AM   #20
CoolHandMoss
Drives: 2013 FRS
I've seen it frequently claimed that the BRZ is 27 lbs heavier than the FR-S due to fancy accessories and such.
CoolHandMoss is offline   Reply With Quote
Old 03-05-2019, 08:58 PM   #21
conehead
Drives: RS 2.0
Since I am not a NASA rules guru, where does an SSC car end up in the NASA classing system? Can it be moved to another class with just a tire change? Thanks
SCCA Solo Spec Coupe Phantom_9192 Tracking / Autocross / HPDE / Drifting 9 06-15-2018 11:10 AM
SCCA pro solo what class TRD_Demon527 Tracking / Autocross / HPDE / Drifting 34 05-11-2015 10:45 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
