Old 05-25-2018, 04:17 PM   #15
leveeyang
leveeyang's Avatar
Drives: Scion FRS
Is there any chance you can take a picture of your hardness wiring? I'm doing mines this weekend.
leveeyang is offline   Reply With Quote
Old 03-26-2020, 05:14 AM   #16
fibber1200
Drives: scion frs 2013
Originally Posted by iLuveKetchup View Post
I've just swapped out my base headlights for the Monogram/RS lights. Most of the steps you see online are for the JDM headlights which are 8-pin connectors with 7 active leads (pins). The US RS lights are also 8-pin connector but with 6 active leads.
To answer your question, you will re-use (or buy new from Toyota/Subaru) the 6-pin connector from your base headlights.
This is the pin-out for the 6-pin connector that you will re-pin to your RS headlights...
---- TAB ----
| 3 | 2 | 1 |
| 6 | 5 | 4 |
1 = yellow - high beam +
2 = black (thicc) - headlight gnd
3 = red (thicc) - headlight +
4 = blue - high beam gnd
5 = black - led gnd
6 = white - led +
Alternatively, you can tap the DRL from the resistor (steps found on the JDM headlight install).
So if I connect the pin6 to monogram headlight white led+ is that mean the led will be on all the time? What if I tap the drl from the resistor(I guess you mean the green wire) where is the green wire should connecting to? And connecting the green wires mean disconnect the pin6 just get the power from resistor? Is that right?
fibber1200 is offline   Reply With Quote
Old 03-26-2020, 09:08 AM   #17
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I honestly don't remember. I forgot I wrote all that crap. I'll have to take a photo of the connector.
iLuveKetchup is offline   Reply With Quote
Old 03-26-2020, 06:06 PM   #18
fibber1200
This is my current wire with the pin 5 and 6 empty on the car connector
And pin1 and4 empty on the headlight connector
Series 10/Monogram headlight install rokius Southwest 10 03-16-2018 10:17 AM
Series 10 Monogram Headlight Swap to 13-16 FR-S... NAEightySix Cosmetic Modification (Interior/Exterior/Lighting) 2 05-05-2017 11:49 AM
wtb headlight for monogram or release serie snowman Canada Classifieds 2 01-03-2016 09:29 AM
wtb: FRS Driver Side headlight Monogram Edition HID oem sokol Want-To-Buy Requests 0 07-18-2015 02:39 AM
Monogram headlight issues Simon Cosmetic Modification (Interior/Exterior/Lighting) 8 10-28-2014 11:48 AM
