Old 01-25-2018, 10:33 PM   #15
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by M0nk3y View Post
RE-71Rs are good pretty much to cord.
Wish that were true for me. Mine were heat cycled at the wear bars. Not sure if driving to and from AutoX and HPDE events contributed to that or not. Most events are at least 1 hr drive from where I live.
smg1138 is offline   Reply With Quote
Old 01-26-2018, 11:16 AM   #16
M0nk3y
Pyrometer says otherwise. How do you draw an underinflated conclusion from even graining across the entire surface of all 4 tires?
These tires have exactly 0 street miles, and rested after the first heat cycles.
How long were tires sitting after the first heat cycle?
I've ran pressures varying from 25 PSI to 32 PSI on my previous STX BMW and I've witnessed some serious graining on the tires at lower pressures. The RE-71Rs have about a 4-5 PSI window where time isn't gained or lost and tirewear significantly improves.
Graining also is pretty common on tires that aren't heat cycled properly and/or overdriven. Not saying the latter is the cause, but I've seen lots of tire failures on the RE-71Rs just from excessive inputs.
FWIW - The center ridge will always grain until there is a nice bevel to it. However looking at tread depth even on the shoulder those tires are nowhere near close to done
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
tigermack (01-30-2018)
Old 01-26-2018, 01:44 PM   #17
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
The term "good to the cords" really depends on the surface you race on and the car setup.
For instance Qualcomm Stadium (aggregate asphalt) for any ST car needs tire tread depth deeper than 5/32" and a somewhat compliant setup to be fast.
El Toro (grippy asphalt and concrete) could run RE71R down to the cord on the same setup.
When I lived in San Diego, I would make a pile of tires that were below 5-4/32 and save them for events at El Toro. This was on different generation of tires too (Z1 Star Spec, Toyo R1R, Hankook RS3) so that confirms that its a site thing more than a tire thing.
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
The Following User Says Thank You to oinojo For This Useful Post:
Old 01-27-2018, 02:38 AM   #18
2 weeks, not that it matters. These aren't slicks
Note that the front and rear grain virtually identically, as do the tires across the entire tread.
Old 01-27-2018, 10:11 AM   #19
M0nk3y
Actually, it kind of does matter surprisingly.
Confirmed with a Bridgestone rep - the RE-71Rs need a 24 hour rest after the first heat cycle in order for the bonds to break and re-form in order for the tire to work its best.
If not, then you can get some graining or undesirable tire wear. I've certainly seen it
Kyle H. - #89 STX
smg1138 (01-27-2018)
Old 01-28-2018, 01:41 AM   #20
Robbie
In the slipstream
My experience is that RS4’s are just as fast as RE71R’s but have much, much better wear. Not scientific A to B testing, but temps were pretty similar for when I ran my best times on each tire and the car, track and setup had not changed.
Robbie is offline   Reply With Quote
The Following 2 Users Say Thank You to Robbie For This Useful Post:
lutfy (01-29-2018), MisterSheep (01-29-2018)
Old 01-29-2018, 03:00 PM   #21
That just means you're driving them at the same pace. Drive harder until you're exploring the limits of traction, not where you think the limit is, and you'll see vastly different results in grip.
Think back to your experience, and as yourself, how often were the tires screaming? Both tires make noise at the edge of traction.
juliog (01-29-2018)
Old 01-29-2018, 04:24 PM   #22
Robbie
In the slipstream
:roll eyes:
Despite your assumptions, I have a good idea where the limits of traction are and both tires were being utilized to their limits. And given I’ve not seen anyone get close to my times at this particular track without much grippier tires or a lot more power in a twin, I’m confident that I’m doing a good job of getting the most out of them.
There’s also a Tire Rack test backing this up.
The Following User Says Thank You to Robbie For This Useful Post:
Pat (01-30-2018)
Old 01-29-2018, 05:14 PM   #23
juliog
juliog's Avatar
Drives: 86
RE71R are easily 2-3 seconds faster than RS4 (or NT01/RC1!) on a 2 minute course. RS4 aren't particularly fast among the current crop of 200 treadwear tires. RS4 have a wider window to put down hot laps than RE71R. This is all common knowledge... anyone arguing to the contrary needs more seat time across a variety of tire compounds
I put the first 5 heat cycles on Mike's tires. I purchased the tires exclusively to *easily* achieve the naturally aspirated 86/BRZ record at Buttonwillow Raceway Park, which I did with a lap time of 1:59.5. I still left some time on the table..
The faster 86/S2000 guys in SoCal usually thrash RE71Rs in less than 3 track days. They're fast tires but expensive, and also not that fun for HPDE because after 2 hot laps they over heat and you're better off ending the session.
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
TofuJoe (08-12-2018)
Old 01-29-2018, 06:20 PM   #24
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Looks like we've reached a consensus; the RS4 is slower but last longer and is more heat tolerant which makes it better for non-competitive lapping, while the RE71 is faster but wears more quickly and is less heat tolerant.
For a time trial go with the RE71 and for a HPDE go with the RS4.
The RE71 works on track, so if you have to have a set for autox you can use it on the track but with an aggressive driver you'll get considerable wear. If you autocross with an RS4 you will be at a disadvantage.
14stu is offline   Reply With Quote
The Following 4 Users Say Thank You to 14stu For This Useful Post:
CSG Mike (01-29-2018), kch (01-30-2018), Lynxis (01-29-2018), trvth (02-05-2018)
Old 01-29-2018, 07:16 PM   #25
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
just want to point out that the last page+ of posts did nothing to address my question for OP: why do you want to change to a "faster" tire? have you already maxed out RS3/RS4 as far as usage is concerned, or do you want to just slap on stickier tires to seemingly go faster with zero improvement in skill?
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
CSG Mike (01-29-2018), strat61caster (01-29-2018)
Old 01-29-2018, 07:17 PM   #26
sw20kosh
Drives: 2013 Black FR-S
This has not been the case here in CA. RE71R is seconds faster. It is called a cheater tire for a reason.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
86_IT (04-28-2019), CSG Mike (01-29-2018)
Old 01-30-2018, 02:13 PM   #27
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Look dude, I'm just looking into different tires because I'd like to try out different tires. Not "better" tires per say. Just trying to get everyone else's opinion on other tires.
Instagram: trevor.parque
Old 01-30-2018, 02:33 PM   #28
strat61caster
strat61caster's Avatar
Because amateur motorsports is full of people who can't accept change.
I witnessed another "cheater tire" scandal 10 years ago, lots of bitterness and accusations then as there are surrounding the Bridgestone's. How does that series cope 10 years later? That tire is now the spec tire. Bridgestone and BFG made a great tire for a single purpose, they succeeded, get over it.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
JazzleSAURUS (03-07-2018), trvth (02-05-2018)
We've got some new competition it seems... tbwoodlee Other Vehicles & General Automotive Discussions 11 06-12-2013 10:53 AM
possible competition jmaryt FR-S / BRZ vs.... 98 10-01-2012 10:31 PM
Looks like there's some new competition... SOB FR-S / BRZ vs.... 19 01-11-2012 12:25 PM
Kia K9, competition for FR-S? 1660 Other Vehicles & General Automotive Discussions 15 07-07-2011 11:12 PM
Possible Competition brandon Scion FR-S / Toyota 86 GT86 General Forum 14 02-21-2011 04:59 PM
