| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2014 scion frs
I park my car in winter too. I just leave it in the back yard and start it to move for snow clearing once a month, letting the coolant and oil heat up to operating temp. I run the AC and heater as per a Toyota issued PDF on long term lot vehicles. Other than that, I shoot squirrels on sight. Airguns are great for that.
#17 |
Drives: 2017 BRZ
Check your bumper for nests. Was just working on my car today and I noticed the outer corners of the bumper seem to accumulate every twig and leaf and whatever else has ever fallen on the car so it's pretty much ready for something to move in.
#18 |
Huge E85 fan!
Drives: 2016 Scion FRS
cover your intake and tailpipe. There's a ton of different opinions on what will repel rodents, but I'd try all of them if you even saw one around.
Did you use fuel stabilizer? If not, do it now and drive over and fuel up- top it off. Gas with Ethanol in it will start to stratify in a couple months and when you go to start it, your engine will get a big gulp of almost pure ethanol. |
#19 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Could be a lot worse. I was reading about a guy who parked his $1.8+M bizjet on the ramp at Dallas Love for a couple of days. When he started the engines, one went into a hot start so he shut both down. Turns out a swarm of bees had set up housekeeping in one of the engines. Repair ran over $400k.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | Tcoat (01-28-2018) |
#20 | |
Drives: 2015 White Series.Blue BRZ
#21 | |
#22 | |
#23 | |
#24 |
Northeast PA sucks for salt use. I have a truck for the winter and I was trying to keep this car for a very long time. If it was just cold, I'd drive it on sunny/dry days, but with salt all over the roads, it's putting a lot of unnecessary wear and tear on the vehicle.
#25 | |
#26 |
So i just checked on it. Inside looks and smells exactly the same as I left it. No evidence of creatures or moisture in the cabin. Engine bay looks fine with no evidence of chewed wired. Exhaust has no evidence of rodents The car cover tightly presses against the exhaust, so i assume nothing can get in there. We also have very little rodent presence where I live. I might have seen less than 5 squirrels in the 4 years I have lived here, which I thought was odd after the first year.
#27 |
#28 |
This is the reason why I store it for the winter. This car was purchased in sept 2014 and this is what the engine bay looks like today with no cleaning. The rain, snow, and salt would have made this look like a dirty sock. Side question... does the little water mark on the intake concern anyone? Should i take it apart and see if anything is inside? |
| Stored my BRZ for the winter :( | pkolanko | BRZ First-Gen (2012+) — General Topics | 36 | 12-14-2017 12:51 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 10:39 AM |
| Where are LTFT data stored? | RustySocket | Software Tuning | 7 | 10-04-2015 11:01 AM |
| Winter Tires worth it in Jersey for the remaining of this winter? | Jfheisenberg | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 01-22-2015 11:58 AM |
| FRS/BRZ used to deliver Sysco food stored in sheds | BRZY | Northern California | 3 | 09-01-2014 08:03 AM |
