Old 12-19-2017, 11:04 PM   #15
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Originally Posted by armstrom View Post
To be honest, a fuel pressure gauge is of limited value for daily driving. On the track? Sure... or in my case, for diagnostic purposes. I never really installed a gauge, I simply built my own gauge "receiver" with an Arduino and LCD display. I was trying to diagnose a lean condition I was experiencing so checking fuel pressure was one of the things I needed to check. I still have the sensor installed but no gauge installed. I will eventually complete my custom wiring to allow me to switch between my fuel pressure sensor and Wideband O2 sensor to log though the narrow-band O2 sensor ECU input.
-Matt
I didn't know what else to get. I have most of the important stuff covered with the first 2 gauges . Any suggestions for a different item to track?
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 12-19-2017, 11:59 PM   #16
humfrz
Old school would be an amp meter.
Today, maybe a voltmeter would yield more useful information.
Kind of boring ....... but, there ya go .......
humfrz
Old 12-20-2017, 01:21 AM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
If all main readings are already covered, for me would be interesting to see from non-engine things real-time temperatures of brakes and/or tires, if some sensor for that can be installed and it's readings passed to gauge, as often when arriving at pitstop temps are already cooled off. Even more so with cooling off lap. Of course, not dailydriving importance item, but would be handy for track.
Old 12-20-2017, 04:20 AM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by x808drifter View Post
If you can only have 3 gauges...
Boost/AFR Like you have.
Oil temp/Press
EGT
On top of that I'd personally have water temp.
One with actual numbers, but there are other options like an OBD2 reader.
Fuel Press is nice but imo unneeded.
Maybe if you track it and are seeing enough side G to cause fuel starvation.
Gauges to help tune.
Boost
AFR
Fuel Press
EGT
Gauges to make sure the car is running ok while driving.
Boost
AFR
EGT
Oil Temp/Press
Water Temp.
Edit: If tuned properly with that boost/AFR gauge the ecu should pull boost and possibly even be able to put the car into limp mode if the car starts going lean from fuel starvation.
All of this ^^^
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2017, 04:19 PM   #19
Strife26
Strife26's Avatar
So then it is beneficial to have EGT + AFR gauges? I had mentioned the EGT previously, but figured maybe it was overkill (and deleted the post) as what I was reading is typically you tune with one or the other.
So I can get water temp or EGT gauges instead of the fuel pressure.
Thanks so much for the help so far, everyone!
Old 12-20-2017, 10:34 PM   #20
Strife26
Strife26's Avatar
I'd rather be harsh with the truth than have someone jump in over their head and destroy their engine.
Not saying OP doesn't, but I err on the side of caution.
Oil temp/Press
EGT
Boost
AFR
Fuel Press
EGT
Boost
AFR
EGT
Oil Temp/Press
Water Temp.
Can also throw flex fuel gauge (ethanol content) in there as well if going that route.
I thank you for the concern, but I am all in regardless of my lack of knowledge. I am learning a lot and I already know some. I purchased a couple books I am finishing up too.
I was just randomly picking a gauge out of my options. The ethanol content would be nice, but I am 300 miles from the nearest E85 besides the whopping 5 gallons in my garage, heh. I believe the etune comes with E85 option too, and if not I can always get that, but it won't be often.
I do know there are two different types of injectors. I do not fully understand the difference yet, but I will read up on it to understand it better. I now know the fuel pressure gauge wasn't the best option. I am returning it for something a little easier.
After looking at my options I am going to go with Water Temp/Battery Gauge Kit. It's $50 cheaper and I have a compact Odyssey battery due to the turbo kit design. I'd like to keep track of that tiny battery, just in case.
Again, thanks a lot for all the info/help. Now I just need them to ship the damn turbo...already delayed almost a month so far.
DIY fuel pressure gauge install armstrom DIY (Do-It-Yourself) Guides 1 05-21-2018 03:18 PM
-=-=SOLD-=-=- AEM Fuel Pressure Gauge+Sender Ivegotamain2 Interior Parts (Incl. Lighting) 0 09-29-2016 11:38 AM
Aftermarket Fuel pressure gauge FutureFT86 Engine, Exhaust, Transmission 2 03-10-2016 10:22 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
