Old 01-13-2018, 03:07 PM   #15
Resolute
in the recliner of rage
Drives: Asphalt FR-S
While lateral traction increases with additional load on a tire, it does not increase at a linear rate. As an example, if your front outside tire has 1000lbs of load on them from weight transfer in a turn on flat asphalt, and this produces 900lbs of lateral traction as determined by the tire's characteristics, this would result in a maximum lateral force of .9g before they lose grip. When you turn in while heading downhill, even more weight is transferred to the front outside tire, so it now has 1200lbs of load, but this may only produce 975lbs of lateral traction, which now limits you to a maximum lateral force of .8g in the turn before they lose grip. So you're right, traction does increase with additional weight transferred onto a tire, but not at the same rate, which is why the maximum lateral force the tire can produce actually decreases when turning in downhill.
Resolute is offline   Reply With Quote
The Following User Says Thank You to Resolute For This Useful Post:
nico_rsx (01-15-2018)
Old 01-13-2018, 03:23 PM   #16
HSUBLU
Drives: 2017 BRZ WR Blue
Originally Posted by hpde_addict View Post
Intuitively, I thought that when the car is going downhill, more weight is transferred to the front tires, leading to the front tires gaining grip and rear tires losing grip. However at the Thunderhill skid pad, I noticed that when going downhill, it is much more difficult to get the car to oversteer compared to level and uphill. And when I'm already drifting in the downhill portion, my car tends to go outward like in understeer. The test was just driving around in a constant-ish circle, progressively adding throttle. What's mechanics are happening that's leading to this behavior?
Another great place to get some practice on this would be Sears Point, on turn 2 for uphill, and the Carousel for downhill - they're both drastic enough that on a relatively traffic-free session you can get some really good practice on the control into and out of the turn.
HSUBLU is offline   Reply With Quote
Old 01-13-2018, 08:36 PM   #17
ROADRACER
Drives: unlimited cheap build N/A track car
Originally Posted by TommyW View Post
You're overloading the front outside tire downhill and overloading the outside rear tire on uphill. Those are the tires responsible for the most grip in those circumstances
Yes, I thought that's what I just said. Understeer on downhill turns and oversteer on uphill turns. Exceeding the tires static coefficient of friction. Same as the OP. I don't know of a way to setup the car to lessen this effect. Im not sure there is a way.
ROADRACER is offline   Reply With Quote
Old 01-13-2018, 08:44 PM   #18
ROADRACER
Very nice explanation!!! I think we have a winner.
Old 01-13-2018, 08:57 PM   #19
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Better to drive those corners a bit differently rather than modifying the car.
Old 01-13-2018, 08:58 PM   #20
TommyW
TommyW's Avatar
Yes, I thought that's what I just said. .
Sorry didn't see your post however yes correct.
Old 01-15-2018, 10:42 AM   #21
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Best answer by far!
Thanks for taking the time to explain what actually happens.
nico_rsx is offline   Reply With Quote
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 06:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 10:42 AM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 12:06 PM
