Old 11-08-2017, 01:37 PM   #15
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Jeez.
This + I/H/E + tune... that's a lot of money just to make 200whp on pump gas.
TylerLieberman is offline   Reply With Quote
Old 11-08-2017, 01:55 PM   #16
StraightOuttaCanadaEh
Wes
Originally Posted by nikitopo View Post
A 15 hp peak power increase (also speculating) would be a very good gain for a NA car. It does not give the gains of a SC, but you don't put either a 60lbs. additional weight in your engine bay.
but the price!
Old 11-08-2017, 02:08 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
but the price!
If you want to stay NA, then you have to pay. I 've paid already the cost of 2 superchargers and now I'm going for the 3rd.
Old 11-08-2017, 02:12 PM   #18
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Why not just install the red top from the 2017/2018?
Opie is offline   Reply With Quote
Old 11-08-2017, 02:23 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because that doesn't have ITBs.
Old 11-08-2017, 03:19 PM   #20
gtengr
Drives: 2017 BRZ
Originally Posted by guybo View Post
The distance from the MAF to the ITB's is too far to make much difference IMHO. Air is measured at the MAF and the time it takes for the air to travel to the throttle plates is where much of the response lag comes from.
The lag is in the time for newly demanded air at the throttle blade to reach the cylinder. The distance from MAF to ITB on the 86 would be less than it was on my old M3.
gtengr is offline   Reply With Quote
Old 11-08-2017, 05:02 PM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Those aren't independent TB's anyway. There's 1 MAF and the throttles all work at the same time, not independently. They are 4 separate throttle plates. The MAF to TB distance is a real thing and affects throttle response. I'm sure it'd be better than stock since there's less plenum volume in vacuum, but it'd take some serious engineering to make true ITB's and a custom tuning solution like MOTEC and 4 MAF's to make it so each TB can independently work.
If anyone does this mod, I want to see numbers.
Old 11-08-2017, 05:32 PM   #22
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Those aren't ITB's anyway. There's 1 MAF and the throttles all work at the same time, not independently. They are 4 separate throttle plates. The MAF to TB distance is a real thing and affects throttle response. I'm sure it'd be better than stock since there's less plenum volume in vacuum, but it'd take some serious engineering to make true ITB's and a custom tuning solution like MOTEC and 4 MAF's to make it so each TB can independently work.
I believe IRTB would be a more correct term.
Individual
Runner
Throttle
Body(bodies)
Old 11-08-2017, 06:36 PM   #23
gtengr
Drives: 2017 BRZ
ITB = individual throttle bodies, not independent. I'm not aware of any car that runs individual cylinder MAF sensors and throttles that operate independently of one another. It's possible, but I think it's safe to say that's not what is meant by ITB's in the sub-$150k car realm. Do you know of any examples?
Old 11-08-2017, 07:08 PM   #24
mav1178
mav1178's Avatar
A good example of this in action is the RB26DETT found in R32-34 GT-R. 3 sets of 2 throttle assemblies, 6 individual throttle bodies via 2 MAF (each MAF feeding a turbo)
-alex
Old 11-08-2017, 07:37 PM   #25
gtengr
Drives: 2017 BRZ
-alex
That's different. Those throttles are synced, not independent. And I was specific about a MAF sensor per cylinder because the other poster specifically said you'd need 4 MAFs to make it run right on an FA20. I know it's common to run split MAF sensors in situations where you have 2 intakes (two turbos, V8 with an intake feed per cylinder bank, etc). The point was that running a single MAF sensor doesn't represent a hindrance to feeding 4 ITBs, and that having synced individual throttles is the standard way of running ITBs. OEM's do it all the time.
Old 11-08-2017, 07:45 PM   #26
mav1178
mav1178's Avatar
So how can an old school ITB setup be truly independent? All cars with ITB only have one cable from the gas pedal, so they are all synced. Same with the Greddy unit launching, same with the SARD unit launching.
Once the air is metered properly, ITBs work the best when the runners feeding air to them have equal flow coming in. That's the most important part.
Old 11-08-2017, 08:09 PM   #27
gtengr
Drives: 2017 BRZ
Now you understand why I was asking the other poster for examples of cars that use these independent throttles, because I haven't heard of it either. My post was very specific when you go back and read it: "I'm not aware of any car that runs individual cylinder MAF sensors and throttles that operate independently of one another."
Old 11-08-2017, 08:18 PM   #28
mav1178
mav1178's Avatar
I know, but I quoted yours because this type of throttle setup in a practical application usually involves 1) 1 or 2 MAF depending on the intake setup, and 2) individual throttle bodies that are controlled via a single actuator/cable assembly.
We're talking about the same thing. In practice, ITB setups are NEVER independent throttle bodies unless you are running engine management on a cylinder by cylinder basis.
How to build ITBs celek Engine, Exhaust, Transmission 62 05-20-2016 01:20 PM
Finally done with my A** VakaGT FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-22-2014 03:48 PM
Dat sound - ITBs RWD_only Engine, Exhaust, Transmission 88 11-18-2014 04:19 PM
20v ITBs Nafe NEW ZEALAND 4 05-20-2014 08:03 AM
Finally found another AE86 for sale.. EJ20 Other Vehicles & General Automotive Discussions 11 06-21-2011 03:19 AM
