#15 |
Drives: 2013 Hot Lava FRS
What I'm basically implying is that if you have to do an emergency stop, just use your right foot if you don't want a high chance of fuckin up because you slipped off the brake pedal because you have both feet on it.
#16 |
Drives: '17 BRZ Premium. Totaled: '16 FRS
which is why i have to rotate them 45... so they dont slip off... which is why i'm asking about a wider pedal... LFB gains you a huge amount of time... when going from gas->brake... you dont have to pick up and move your foot over and then apply brake... you just start applying brake.
#17 | |
Drives: 2014 FR-S
But, instead of all of that feet confusion, why not just learn how to downshift without the clutch? If your heel/toe is that good, you can't be far off from being able to do it without moving your left foot. I do find it odd that you're presenting a dire must-stop-nao scenario with a strong interest in how you'll get back to speed before you've even successfully avoided whatever the emergency was.
-Mike
#24 CS/CSR |
#18 |
Drives: 2023 BRZ
this thread gave me cancer
#19 | |
Sent from my Nexus 5X using Tapatalk |
#20 |
#21 |
My VTEC fluid is full
Drives: EFF JAY
#22 |
Drives: 2024 GR86/ 2015 FRS
If you have a Moto-east (Ecutek) tune, it has blip throttle downshift.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#23 |
OP - Why do you think you need to all of the sudden LFB?
Kyle H. - #89 STX
#24 |
Don't need it. Prefer it though. Do it all the time now... foot just stays there and goes to use the clutch when I need it. I can do the transition from lfb to rfb with the pedal down just fine without fucking up the brake pressure, but turning my leg so far to the side is kinda annoying. it would be easier with a wider pedal and I figured other people would have figured out a better pedal setup already...
#25 | |
Drives: 2022 GR86
Go listen to some podcasts at http://autocrosstalk.com and hear what all the top autox drivers in the country think about it. Most all of them say LFB is not faster and don't bother learning to switch if you already RFB. In the end it's your preference, but I don't think there is any benefit unless you really really master it. Even then, the benefit is so minimal it's likely a wash.
#26 | |
#27 | |
Drives: 2014 Subaru BRZ
If you can't brake hard enough with just your left foot, there is something physically wrong with you. I have confidence that you can get into ABS with just your left foot, there is no reason to have both feet on the brake pedal. Left foot braking is a technique that helps rotate cars that have less than ideal balance, like many awd or fwd cars. It is also helpful in rally or low grip situations where you have to use weight transfer to accommodate low grip. Brush braking, trail braking, and left foot braking are of limited use in a twin. Stop using so much brake and just lift to transfer weight, you'll go faster. Brakes only slow you down. |
#28 | |
Drives: 2022 GR86
Personally I would be trying avoid putting 2 feet on the same pedal, but that's just me. Hope you find a solution to your problem.
| left-foot braking with AT | mdm | Scion FR-S / Toyota 86 GT86 General Forum | 169 | 06-05-2016 11:25 AM |
| That left-side vertical streak of residue left by windshield wipers | tzhu07 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-15-2015 12:23 AM |
| Foot pain while braking hard? | daiheadjai | Other Vehicles & General Automotive Discussions | 19 | 04-05-2015 08:46 PM |
| WTB Red Bumper, Left Fender, Left head light, Clear side markers | carlossanchez89 | Want-To-Buy Requests | 0 | 09-01-2014 03:43 PM |
| How much do you like heel-toeing or left foot braking? | USMCMike | Other Vehicles & General Automotive Discussions | 20 | 01-15-2010 04:20 PM |
