Old 10-11-2017, 08:39 AM   #15
Bfranklyn86
Drives: GT86 Harrop S/C
Originally Posted by Kodename47 View Post
It's MAF tuned. What do you mean by rough bottom end?
Jerky on part throttle down the rev range.
I'm getting a retune soon anyway (new manifold) so will raise the issue then.
Bfranklyn86 is offline   Reply With Quote
Old 10-11-2017, 10:53 AM   #16
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
Originally Posted by sobrz View Post
and here she is at sunrise on the PCH last weekend
Wow, great photo, black looks great in liquid light.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 10-11-2017, 01:18 PM   #17
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by mrg666 View Post
245 width fits minimum 8" wheel width. Stock 7" rims can take maximum 225 width. These are manufacturer specifications. Of course you are free to try any size and show us
That’s why I asked. I’ll leave the 245 experiment to someone else
I like driving!
86 South Africa is offline   Reply With Quote
Old 10-11-2017, 01:39 PM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
For 7" it's min 195, ideal 205-215, max 225. Of course one can fit even narrower (overstretch) or even wider then these suggested by manufacturers optimal tire widths, but preferably knowing pros & cons (mostly later, like harder to mount & increased propability for overstretched tire separation from wheel and easier to get kerb damage to wheel paint, or like adding much more tire sidewall flex if tire is too wide for wheel width, resulting in too mushy handling for what tire is capable, and uneven tire wear in both cases). For some pros may overweight cons. Eg. removal of tire flex in stretched tires for sharper turn-in even with softer sidewalled tires or looks considered cool for some niche people, or getting slight extra grip of wider tire fitted for auto-x, if class rules prohibit non-stock sized wheel usage but won't limit tire choice.
Old 10-11-2017, 03:14 PM   #19
Tor
Tor's Avatar
Drives: Toyota GT86
Probably messed up load limits. Post a log to datazap and let someone look at it.
Tor is offline   Reply With Quote
Old 10-11-2017, 05:21 PM   #20
steve99
Deliceous supercharger tunes seem to use some form of speed density, so almost impossible to tell whats going on from logs unless you know what been set up. The fueling doent follow commanded afr pi\di ratios are manipulsted and even timing appears to be as well likely using custom maps in ecutek.
Old 10-11-2017, 06:02 PM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
it's not that.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-11-2017, 06:35 PM   #22
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I routinely recommend Delicious as a first choice to anyone in Australia with a non-budget Fi kit.
Old 10-16-2017, 06:41 PM   #23
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I don't think it's our tune on that particular vehicle, as I haven't done any Harrop's in the UK to my knowledge. :-)
But yes, we have nearly every single custom RaceROM map utilized fully in our forced induction tunes.
-Zach
Mach V Awesome / Wicked Awesome wheel gallery Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 80 05-08-2021 12:34 AM
What an awesome car! pnirenstein Scion FR-S / Toyota 86 GT86 General Forum 35 07-07-2013 12:09 AM
CHP are Awesome People EAGLE5 Northern California 17 05-15-2013 08:26 PM
Most Awesome Ads ever LS13 Off-Topic Lounge [WARNING: NO POLITICS] 5 10-14-2012 09:55 PM
