Old 10-28-2017, 08:02 PM   #15
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Originally Posted by Ernest72 View Post
2200 rpm going uphill.
Found your problem 🙃
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 10-29-2017, 09:39 AM   #16
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
JDL uel header - Invidia Q300 - plenty of drone at low rpm. Love it when I am on it, but after an hour in the car it starts to wear on you. Just trying to tone it down a little. Some dynamite and ensolite and some acoustic foam should help. Been through this with my 04 WRX at stage 2 with prodrive muffler- it worked for that car.
I also have a header and Q-300. I added the HKS dual resonated front pipe and that helped a lot.
Lunatic is offline   Reply With Quote
Old 10-30-2017, 09:21 PM   #17
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
thanks, I think that would work, but I want to keep the cat. maybe try the magna flow one. need to do some research.
Ernest72 is offline   Reply With Quote
Old 02-07-2018, 08:54 AM   #18
Varelco
Drives: '15 GT86 & '22 GR86
Been trying to quiet down the exhaust note in the car. Took the entire trunk apart and notice a black square on each side. The square has some thin rubber that can move and open to let air in or out and is pretty much exposed to the outside. So exhaust noise can come right in and echo through the trunk. I covered these squares loosely with some ensolite. Anyone else try this. I am in the middle so I have not tested it yet. Plan on getting some more acoustic foam and jam it in there between the square and the side cover for the trunk.
Originally Posted by tshrey View Post
The point of those flaps is evacuating cabin air to draw fresh air in. Plugging them means you don't get the same air flow.
The reason those flaps exist is to equalize the air pressure inside the car. If you seal these you are in theory sealing the car (assuming the windows are up). It doesn't help the HVAC pump and circulate air inside the cabin. They also act like a pressure relief when you slam those doors shut. So yeah, don't block them, they are there for a reason, not to mention blocking them will do nothing. Sound isn't like water, it doesn't just seep in through gaps, it vibrates through the entire car.
Your exhaust is resonating at a very low frequency, unless you intend to fill the cabin with masses of material sound deadening will do very little. The 2 solutions you have are to replace the exhaust or have a helmholtz resonator fitted in your exhaust (this will be particularly big for low frequency)
Varelco is offline   Reply With Quote
Old 02-07-2018, 07:18 PM   #19
Ernest72
helmholz will be done. I did not seal them just stuck some foam down there. it did nothing. this car is just too tinny.
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 12:51 PM
Installed some Sound Deadening! Teeeg28 Scion FR-S / Toyota 86 GT86 General Forum 6 07-08-2014 10:14 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 01:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 02:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 09:09 PM
