#15 |
Drives: 2013 FRS Whiteout
| The Following User Says Thank You to Pure Automotive For This Useful Post: | Sportsguy83 (01-28-2013) |
#16 |
Those brass tees are notorious for cracking at the threads and is exactly what I was talking about.
#17 |
I Love custom Turbo kits
Drives: Limited BRZ
I'm going with the gallery plug. Thanks a lot for your help!!
#18 |
Drives: A Car
Hi guys, I'm planning to install an oil pressure/temp gauge and I was wondering where I could get a more accurate reading. Which is better to put into the galley plug, the oil pressure or temperature sensor? Or is it okay if I just run both on a sandwich plate?
#19 |
Drives: RX-7 / BRZ
@Sportsguy83 did you ever get this finished? Thinking about getting the FastWRX gallery plug / sender relocation kit that was posted earlier for myself.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#20 |
Drives: WRB BRZ
I'd like to do this DIY as well. I'm deciding to install the sensor in the unused gallery plug. Anyone know where I can wire a defi gauge?
#21 |
Drives: Subaru BRZ
I was reading on NASIOC, and some WRX guys are were replacing the idiot light switch with their pressure senders, basically unplugging them, and they didn't have any CEL or issues? Has anybody tried that on our cars?
my plan at the moment is to use that relocator kit posted above, remove the idiot light switch, plug the SS line to where the idiot light switch was, run the SS line to a Tee, then plug in both switch and pressure sender into the T. any real problems with that setup?
2014 WRB BRZ
#22 | |
USMC
Drives: 2013 FR-S 6-MT Raven
#23 | |
Drives: Limited BRZ
I believe left is oil pressure and right is oil temperature.
#24 |
Drives: '14 WRB BRZ Limited
Reviving this thread, so as to not start another one. I am about to install oil pressure and temperature gauges. I am planning to use the galley plug for temp, and the stock pressure sender location for oil pressure. My question is, can I just toss the stock sender and ground the stock sending wire? I don't want the oil pressure dummy light to be on all the time on my dash.
On the WRX the stock oil pressure dash light switch is a normally closed grounding switch that opens and breaks the ground when it senses 2.5 psi of oil pressure. Does anyone know if the FA uses the same type of switch? This document is what gave me the idea |
#25 | |
Drives: Galaxy Blue BRZ
#26 |
I like the sound of that! Thanks for the info! Now just waiting on the galley plug in the mail and I'll be ready to install
#27 | |
Senior Addict
Drives: 86 GT
| The Following User Says Thank You to Fizz For This Useful Post: | Teclis (07-04-2015) |
#28 |
Drives: 2013 Raven fr-s
where are people mounting their gauges? I see the a/c vent gauges, but honestly with as hot as it gets here in summertime I do NOT want to block any airflow to me...I feel like the a/c can't keep up as is...
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
| Aftermarket gauge placement | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-18-2012 01:01 AM |
| Self-diagnostic busses? Specifically oil pressure? | Nezz | Electronics | Audio | NAV | Infotainment | 6 | 08-13-2012 08:34 AM |
| phantom tire pressure warning | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 06-04-2012 09:04 AM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) — General Topics | 17 | 12-12-2011 11:39 AM |
