Old 08-16-2017, 05:10 PM   #15
imnotsureaboutbrz
Drives: between cars...
question for the collective, since we are talking about winter and the temps are already dropping here. Do any of you put sandbags in your trunk?
imnotsureaboutbrz is offline   Reply With Quote
Old 08-16-2017, 06:32 PM   #16
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
No sandbags in the trunk. If you're going to put sandbags, put them on the back seat. But that's really not needed.
The only time I got stuck in the 2 winters driving the FR-S was after the freezing rain turned the snow bank into icy tire cups.
Other than that as long as you stay cool and smooth with your inputs, it's going to be alright
mrderp is offline   Reply With Quote
The Following User Says Thank You to mrderp For This Useful Post:
Tcoat (08-16-2017)
Old 08-16-2017, 08:19 PM   #17
Sand bags are for pickup trucks and RWD cars with a serious front weight bias. We do not have that bias to have to balance out. In fact (and this always gets debates by somebody in Texas or California that has never seen a flake of snow in there life) by putting weight in the trunk you bring the bias way back. Great for getting unstuck in deep snow but a total nightmare if the rear end starts to slide out on you. With the rear bias you will just start to spin in ever increasing circles and there will be nothing you can do about it.
humfrz (08-16-2017), imnotsureaboutbrz (08-16-2017)
Old 08-16-2017, 08:32 PM   #18
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
With close to neutral balance with a 200# payload in the passenger space, the main effect of excess weight in the trunk would be to give it the balance of a hammer. If I wanted that, I would have bought a 911
Shinigami301 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shinigami301 For This Useful Post:
imnotsureaboutbrz (08-16-2017), Tcoat (08-16-2017)
Old 08-17-2017, 04:52 AM   #19
milkydude12
milkydude12's Avatar
Drives: none
Thanks for the info guys . I'm less worried about winter driving the 86 now (now back to trying to get the 86......)
milkydude12 is offline   Reply With Quote
Old 08-17-2017, 09:16 AM   #20
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Get good tires and you're all set.
Something to note: A Honda CR-V has only 1.3" more ground clearance than a stock twin.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
Tcoat (08-17-2017)
Old 08-19-2017, 05:31 PM   #21
mrg666
pessimistic skeptic
mrg666's Avatar
Speaking of good snow tires. Anybody has some experience with Hankook Winter iCept Evo snow tires? I am looking to buy a set of snow tires for coming winter.
Old 08-20-2017, 10:24 PM   #22
Jegan_V
Drives: 2023 Subaru BRZ
The iCept Evo seems to be really really expensive and from the reviews they seem to perform just as well as the much cheaper iPikes. At their price I might as well get the Nokian Hakkapelitta 8, the top rated tire or the Blizzak WS80s which is just as good for a bit more.
I went with the Gislaved Nordfrost 100 for the value choice. Its a lot cheaper than the top tier tires but is not far behind in performance. The 100 is gone now, I'm not sure what changes were made to the 200.
Jegan_V is offline   Reply With Quote
The Following User Says Thank You to Jegan_V For This Useful Post:
mrg666 (08-21-2017)
Old 08-22-2017, 12:03 AM   #23
arxm
Drives: 2013 FR-S, 2023 BRZ
this is my first rwd car, put on some x-ices and to be honest it does really well, not as good as my accord but keep the rpm's low and just be mindful of where/how you drive and its just as good as any other car
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 08-22-2017, 05:06 AM   #24
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
16 inch wheels help as well. That little bit more sidewall makes a difference in the snow.
I have some nice 16" forged wheels in the classified section for sale. Like this example, smaller can be better then a larger wheel (also smaller will be lighter in general, over the same make/model wheel.). Lower weight will always be a high performance desired modification that hasn't got any down falls of doing the change (especially when you're not sacrificing strength in the process).
…… but some people want to do turbos… SC ….. more $$, lowers engine durability….. I digress.
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 08-22-2017, 06:57 AM   #25
I prefer the solid steel wheels for winters. We get a lot of freeze and thaw cycles so the roads can be very slushy. The slush can build up and freeze in spoked wheels and you end up bouncing down the road.
Old 08-22-2017, 02:52 PM   #26
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I feel as if the OP has never driven in snow before. lol
It's pretty much like any other car in the snow.
Old 08-27-2017, 10:45 PM   #27
milkydude12
Drives: none
I've been driving an Auto CRV AWD (2002) in snow for a few years now (the car is now beyond repair, rust, busted engine, sketchy tie rods, signal lights no longer worked properly, breaks were sketchy, ebrake no longer worked, took 2-3 tries to crank over in the winter when it was working). Which is why im upgrading to the Toyota 86 . I just wasn't that confident with driving a RWD in snow, because all my life i've been told that AWD is "NEEDED FOR SNOW". All that changed when I drove a bud's M3 in the snow, however that was for like 15 minutes with not that much snow on the road, hence my hesitance.
Old 08-28-2017, 08:31 AM   #28
roddy
roddy's Avatar
Drives: '13 Ultramarine
@milkydude12 Watch this video.
[ame="https://www.youtube.com/watch?v=JKBdOE2z4O4"]RWD in a Snowstorm - Are we Crazy? - FR-S Long Term #3 - Everyday Driver - YouTube[/ame]
canada, questiion, snow, toyota
TPMS in Canadian 2017 BRZ? wolffbite CANADA 6 04-05-2017 10:31 PM
Canadian 2017 BRZ - good negotiated price? nico_rsx CANADA 16 03-09-2017 11:48 PM
Canadian International Auto Show 2017 STOOPIDSTANCE BRZ Photos, Videos, Wallpapers, Gallery Forum 0 02-28-2017 08:58 PM
2017 Toyota GT86 on Snow and Ice - Video mark0006 Scion FR-S / Toyota 86 GT86 General Forum 11 01-13-2017 02:14 PM
How do you say Yellow in Canadian (2017 Inazuma Edition) DatsunDimer BRZ First-Gen (2012+) — General Topics 40 12-17-2016 01:05 PM
