Old 08-17-2017, 12:45 PM   #15
strat61caster
strat61caster's Avatar
Originally Posted by qqzj View Post
If there isn't a good reason for it, it is pretty much a ripoff.
Here's what others have dug up.
http://www.ft86club.com/forums/showthread.php?t=8267
tl;dr due to the high compression direct injection nature of the FA20 it requires a specific uncommon plug design to operate well.
NGK has some good info on why different plugs matter and the tl;dr there is that different combustion environments need a different kind of spark to operate at the way it was intended to.
https://www.ngksparkplugs.com/about-...rk-plug-basics
Some conclusions you can draw from that: spark plugs are cheap because of economies of scale, there are literally hundreds of millions of spark plugs manufactured every year and I'd bet most of them fall into a few categories. When you make tens of millions of widgets per year you can get production costs very low, but for the FA20/BRZ/FRS/86 they're only making maybe a few hundred thousand per year.
Take the spark plug in a Toyota Camry, instead of making 50 million of those every year you only make 5 million. It doesn't cost any less to setup the factory and maintain the machinery but you are all of a sudden selling 1/10th of before, therefore prices must go up nearly 10-fold to maintain profitability.
And that's how what "should be a $2 spark plug" is now a "$20 spark plug"
(except now rare metals increase base cost but don't necessarily translate into lost profit margin based on economies of scale so we're comparing a $20 plug to a $8 plug)
Why do I think this is true at all? Because if there was any other engine using this spark plug it would have been known years ago and yet every parts website lists it as the only option for this car and nobody else uses it. If you can find something that does then I'll re-evaluate my hypothesis.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
BRZach (08-18-2017), gravitylover (08-17-2017), Tcoat (08-17-2017), Teseo (08-17-2017)
Old 08-17-2017, 12:56 PM   #16
.......but, but, were they NEW Champion plugs ........ or, used ones, you found by rummaging through the trash cans in the service department of the local dealership ......??
humfrz
Brand new. The old 440 Magnum was just really hard on them. Not as hard as it was on fuel pumps though. Anybody that invested in Mopar parts stock then must have made a killing on me.
Old 08-17-2017, 12:57 PM   #17
This ^ All day long THIS^
Old 08-17-2017, 02:54 PM   #18
humfrz
Mechanical or electric fuel pump ...?? How did you manage to mess them up .....
humfrz
Old 08-17-2017, 03:13 PM   #19
humfrz
Mechanical. The heavy cam I had in it would rip them apart. Happened so often that I could change one on the side of the road in 5 minutes. Eventual went electric and just blanked off the hole in the block. Never had an issue again.
humfrz (08-17-2017)
Old 08-17-2017, 03:42 PM   #20
humfrz
Well, no wonder .....
You go and put a big, hairy, long duration, high lift cam in the engine, which the lobe that pushed the arm on the fuel pump, waaay to far and punctured the rubber diaphragm, when it was trying to feed all those carburetors, no doubt linked in series, with enough gas to get your 3 MPG ..... 1/4 mile at a time.......
Damn hot rodder!
humfrz
Tcoat (08-17-2017)
Old 08-17-2017, 04:20 PM   #21
Damn hot rodder!
humfrz
That is the perfect description!
humfrz (08-17-2017)
Old 08-17-2017, 04:52 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Did the same with the 454 in my Chevelle. Didn't go thru mech pumps, just couldn't deliver for two 850 4 barrels.
Old 08-17-2017, 05:19 PM   #23
Sapphireho
Famous Potatoes
Sapphireho's Avatar
So does this mean if/when they stop making the twins we all better go out and buy a few sets of plugs?
Tcoat (08-17-2017)
Old 08-17-2017, 05:29 PM   #24
gravitylover
^^ When the engine design changes appreciably I think it would be a good idea.
The Following User Says Thank You to gravitylover For This Useful Post:
Tcoat (08-17-2017)
Old 08-17-2017, 05:30 PM   #25
strat61caster
You'll be good at least 5 years after it gets shut down (I'd say closer to 10 before things start getting difficult), good manufacturers stockpile parts to keep cars on the road. There's a chance that the plug type actually becomes more common as compression ratios creep up and direct injection becomes more common. But if that doesn't happen and you're looking for plugs in ~30 years good luck.
But that might be true for all spark plugs at that point. And hey, maybe plug manufacturing becomes a niche industry and they build to order anyway.
Predicting the future is hard.
ineedyourdiddly
Tcoat (08-17-2017)
Old 08-17-2017, 08:03 PM   #26
I wouldn't sweat it too much.
Mind you anybody with NOS ones in 30 years can make a killing.
humfrz (08-17-2017), strat61caster (08-17-2017)
Old 08-17-2017, 09:25 PM   #27
humfrz
......ANOTHER old hot rodder ......
humfrz
Old 08-18-2017, 12:14 AM   #28
BRZach
SupaSter
BRZach's Avatar
Drives: 13' BRZ
I asked similar questions before.
http://www.ft86club.com/forums/showthread.php?t=118923
If you go with Toyota branded version, it is $14 each plus shipping. Total about $70. It is still not cheap. But much better than $88. Let's see who can beat this.
I was able to get $68.83 shipped !!
BRZach is offline   Reply With Quote
Spark plug failure BRZ68 Issues | Warranty | Recalls / TSB 9 06-12-2017 07:44 AM
Spark Plug Replacement Dacfrs Rocky Mountains / Great Plains 4 03-21-2017 12:16 AM
P0351 bad spark plug... Jaden Engine, Exhaust, Transmission 3 01-02-2016 10:19 AM
Spark Plug Time !!!! RFB Scion FR-S / Toyota 86 GT86 General Forum 26 11-24-2014 07:46 PM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 12:57 AM
