Old 08-10-2017, 04:23 PM   #15
fang_gt86
FR Noob
fang_gt86's Avatar
Originally Posted by HunterGreene View Post
p.s.--the fuel does not come in contact with the transmission, which is what I think @Tcoat is trying to get at. The assertion that E85 somehow makes your shifting smoother is pure butt dyno.
EDIT: This is with my stock FR-S. Using e-85 or FI, even a tune might change the most effective parts of the powerband. That said, still seems unnecessary to me.
I've been driving since 15k with E85 & 93oct (currently at 65k), the difference is there every time I switch fuels. It could be just my car, the mods and the way I drive. I think since E85 makes the engine less lazy it's easier for me to shift.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 08-11-2017, 03:10 AM   #16
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Originally Posted by fang_gt86 View Post
My '13 was completely fine until 15k when I had Toyota flush out tranny/diff fluid. I got 65k now and 5th gear still grind but I just live with it.
This is what I do to minimize grinding:
* Precise and quick shift and no granny shift.
* No rev match shift. Yes, my 5th gear hates rev match.
* No down shift above 3k.
* E85 also minimize 5th gear grinding. Weird right? But it does helps..
By grinding, do you hear the screeching sound? Or the notchy sound?
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 08-11-2017, 12:20 PM   #17
fang_gt86
FR Noob
fang_gt86's Avatar
I got everything. The faint honk/goose/screeching used to be at 3.5k rpm but now it's moved to 5k and above..
The Following User Says Thank You to fang_gt86 For This Useful Post:
Exrald (08-11-2017)
Old 08-21-2017, 11:43 AM   #18
bravedeer
Drives: Subaru BRZ 2013 Limited Manual
Happy to report that replacing the OEM transmission fluid with Motul 300 solved the downshift from 6th to 5th at high speeds.
bravedeer is offline   Reply With Quote
The Following 3 Users Say Thank You to bravedeer For This Useful Post:
Exrald (08-21-2017), fang_gt86 (08-21-2017), jcw99 (09-02-2017)
Old 08-21-2017, 12:25 PM   #19
fang_gt86
FR Noob
fang_gt86's Avatar
Guess I'll have to try my luck with Motul 300.
Old 08-21-2017, 12:55 PM   #20
bravedeer
Hope it works for you as well. Overall all the shifts are smoother (not notchy) and not hard to shift into 1st or 3rd like sometimes was the case before.
Old 08-21-2017, 02:03 PM   #21
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
The only times I can think of needing to downshift at 70+ mph is 1) Emergency 2)Track racing and 3) driving like an asshat. In the time it takes me to rev-match, downshift and floor it, gaining the necessary speed to pass, I can just put the pedal down in 6th and be going as fast as I need to, frankly. Might as well save your clutch if you are just on the highway.
? thought part of the point of getting a manual was to enjoy shifting so it is odd that you think those are the only valid reasons to downshift.. you aren't even hitting 3 K RPM at 70 MPH in 6th gear so dropping down to 5th should be nothing and certainly preferable if ya want to pass quickly...personally I just stay in 5th and only go to 6th for longer drives on the highway. from my experience, this gearbox does not like slop with the throws or clutch work
HKz is offline   Reply With Quote
Old 08-21-2017, 02:17 PM   #22
bravedeer
I fully agree. When you're at 70mph if you want to pass someone, staying in 6th makes it a fairly slow pass. This is a sports car, being able to downshift from 6th to 5th at a high speed is something basic.
The Following User Says Thank You to bravedeer For This Useful Post:
jcw99 (09-02-2017)
Old 08-21-2017, 03:02 PM   #23
strat61caster
strat61caster's Avatar
Dropping to 4th is quicker.
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
Dadhawk (08-21-2017), sato (08-26-2017), stevesnj (08-21-2017), TheMedakaBox (08-22-2017), TorontoNat (08-21-2017)
Old 08-21-2017, 03:14 PM   #24
? thought part of the point of getting a manual was to enjoy shifting so it is odd that you think those are the only valid reasons to downshift.. '
This isn't a "manual" thing, I do this all the time with the AT, and in fact as @strat61caster mentions below, I usually drop to 4th (double-tap on the paddles). I've done it so much at this point it's second nature.
stevesnj (08-22-2017), strat61caster (08-21-2017)
Old 08-21-2017, 03:21 PM   #25
HKz
Reformed
HKz's Avatar
indeed, I get that dropping gears has nothing to do with the type of trans, just found it was quite odd that the poster didn't think it was logical for a driver to drop a gear on a MT unless they are hooning around..
The Following 2 Users Say Thank You to HKz For This Useful Post:
Dadhawk (08-21-2017), strat61caster (08-21-2017)
Old 08-21-2017, 03:54 PM   #26
Agreed!
Old 08-22-2017, 12:00 AM   #27
stevesnj
stevesnj's Avatar
Downshifting at 70mph to pass for whatever reason is normal If someone say's not to do this for any reason they need to get an automatic.
My 2016 Build thread
Old 08-22-2017, 12:57 AM   #28
HKz
Reformed
HKz's Avatar
#passiveaggressivejabatautomatics
think i did it right @Tcoat
The Following 3 Users Say Thank You to HKz For This Useful Post:
Dadhawk (08-22-2017), stevesnj (08-28-2017), Tcoat (08-22-2017)
Downshift to 1st at low speed 86wtywly Scion FR-S / Toyota 86 GT86 General Forum 34 09-12-2016 01:53 PM
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 03:59 PM
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 11:39 AM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 06:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 01:37 AM
