Old 08-07-2017, 07:53 PM   #15
Darkrune
Darkrune's Avatar
Drives: 2017 86
You're right. That is the wrong spring for the front strut.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
The Following User Says Thank You to Darkrune For This Useful Post:
Clipdat (08-08-2017)
Old 08-07-2017, 08:22 PM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If he did in fact put the wrong spring on the wrong side of the car....
Then comes back with "I'm gonna cut em if this is normal"
Old 08-08-2017, 02:25 AM   #17
Tamukas
Drives: Clean
Aren't the springs with the closer/tighter section of wound spring on the top supposed to go in the rears? But these are on the front? Front and rears reversed maybe?
Yeah.. this must be it.. But the wierd thing is that everything seemed to fit properly. Well, I guess I just will roll up my sleeves and start over. Thank you for your reply!
Tamukas is offline   Reply With Quote
The Following User Says Thank You to Tamukas For This Useful Post:
Old 08-08-2017, 12:52 PM   #18
wparsons
wparsons's Avatar
It's been a while since I've had a set of springs in my hand, but aren't the rears a smaller diameter coil?
flickr
Old 08-08-2017, 12:57 PM   #19
strat61caster
strat61caster's Avatar
No, 90mm ID for both.
ineedyourdiddly
wparsons (08-08-2017)
Old 08-08-2017, 03:46 PM   #20
wparsons
wparsons's Avatar
Show's how much attention I really paid when I installed my springs
flickr
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 02:49 PM
FS: stock BRZ springs, Eibach Pro Kit springs + Stock shocks (socal/OC) tracerit Brakes, Suspension, Chassis 7 04-02-2016 12:04 PM
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
