Old 08-03-2017, 02:19 AM   #15
choi0706
Drives: t
reset steering angle sensor. have you replaced the tie rods ?
choi0706 is offline   Reply With Quote
The Following User Says Thank You to choi0706 For This Useful Post:
stevesnj (08-03-2017)
Old 08-03-2017, 07:47 AM   #16
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Are these turns the same? On the twisty roads I go on, I can get my traction control to kick in easier on the right turns because my right turns are sharper than my left turns (driving on the right hand side of the road).
Also as others have mentioned, try driving with a same size passenger, it makes noticeable changes how my vehicle handles during turns because of weight shift.
And for me, regarding driver confidence, on a sharp right turn I'm not as afraid I'm going to swing my rear into a wall as my left rear is farther from the edge of the road than when I'm turning left where my right side rear is closer to the wall, again assuming right hand side of the road driving.
Pointmutation is offline   Reply With Quote
Old 08-03-2017, 07:59 AM   #17
Tokay444
Turn it off. Problem solved.
The Following User Says Thank You to Tokay444 For This Useful Post:
DandoX (08-03-2017)
Old 08-03-2017, 08:09 AM   #18
stevesnj
stevesnj's Avatar
VSC and TC turn on automatically after certain conditions are met. Unless you get the @86Nanny the modes are temporary.
Here's a DIY on Zero Point Calibration. It's performed on a Toyota so maybe there's an explanation for our cars specifically out there.
[ame="https://www.youtube.com/watch?v=0GZS_Nqub1U"]https://www.youtube.com/watch?v=0GZS_Nqub1U[/ame]
My 2016 Build thread
Old 08-03-2017, 09:17 AM   #19
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
^ +1 on alignment if there truly is a problem
One of the best experiences I've had with these cars was doing rear LCA's and correcting camber without touching toe.
Dropping a degree of camber without adjusting toe made the car truly undrivable as you passed 15mph. TCS light flashing over pebbles on the road, or the slightest of wheel movements.
Fix the toe, tweak the camber, fine tune the toe again, and the thing tracked straight and had more grip than it ever had.
A dash of toe in the wrong way can absolutely RUIN a car.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
strat61caster (08-03-2017)
Old 08-03-2017, 12:34 PM   #20
Tokay444
Unless you get the 86Nanny, OR do the pedal dance...
Old 08-03-2017, 01:36 PM   #21
JazzleSAURUS
Untrue. Pedal dance resets when you restart the car.
Old 08-03-2017, 01:56 PM   #22
Tokay444
Irrelevant, and nothing I said was untrue.
Old 08-03-2017, 02:26 PM   #23
stevesnj
stevesnj's Avatar
Pedal dance is a pain. He should IMHO just start with a Zero Point then go from there. @86Nanny is worth every penny and the new version coming soon has more features but both are meant for the track not street.
Old 08-03-2017, 02:30 PM   #24
stevesnj
stevesnj's Avatar
Originally Posted by dvniemela View Post
2013 FR-S. When cornering to the right, the traction control will kick on and car will act strange. Does not do that when turning to the left. Any ideas?
This with everyday around town use or on the track?
Old 08-03-2017, 05:51 PM   #25
cjny
Drives: 2016 BRZ
Maybe you wanna start with the simplest explanation: Right hand turns on the street tend to be shorter radius than left hand turns. At a constant speed the shorter radius turn will push tire grip closer to maximum.
cjny is offline   Reply With Quote
The Following 3 Users Say Thank You to cjny For This Useful Post:
stevesnj (08-03-2017), strat61caster (08-03-2017), wparsons (08-03-2017)
Old 08-03-2017, 08:34 PM   #26
stevesnj
stevesnj's Avatar
Make 4 rights and then 4 lefts and see where you end up
Old 08-04-2017, 07:49 AM   #27
Tokay444
There's no telling where you'll end up. That entirely depends on the angle of each corner.
stevesnj (08-04-2017)
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
corner exit traction autobrz BRZ First-Gen (2012+) — General Topics 50 06-09-2013 01:55 AM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
