#15 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (07-21-2017) |
#16 | |
Armchair diagnose is bad enough but when people don't even have any details it becomes even worse.
#18 |
Yep bad return spring then. Pretty unusual but I guess it falls into the stuff happens category. Will be warranty.
| The Following User Says Thank You to Tcoat For This Useful Post: | Lust (07-21-2017) |
#19 |
Drives: 2017 Subaru BRZ
#20 | |
![]() humfrz |
#21 |
#22 | ||
"MTEC has released a spring shift kit for the Scion FR-S, Subaru BRZ, and Toyota GT-86. We had these installed in our silver car at 86Expo and everyone that tried the shifter could not believe the difference these made. These helps guide the shifter into the right gears. I'll let the youtube videos do the taking but for the money nothing will improve shifting like these do!"
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (07-21-2017) |
#23 | ||
#24 | |
humfrz |
#25 |
Drives: BRZ 2017 Pure Red, MT
Really?!? You're saying your car is completly stock, then you say you have installed probably the only part in all the aftermarket parts that can cause the problem you described....
Basically having a full blown race car with a stock transmission would have less chance of causing that problem than having only that little spring. This spring is basicaly the most important part in the left/right motion of the shifter. You either didn't installed it properly, or it broke, or you inverted the 2 springs in the kit. Put back the stock springs, and hope nothing important got damaged. |
#26 | |
| The Following User Says Thank You to Lust For This Useful Post: | Tcoat (07-21-2017) |
#27 | ||
You could try installing them and see if that fixes it but I personally would take it in and have it checked first.
#28 |
I can kinda see how one may get confused but still... in the previous post I did say completely stock. My follow up question was going to be if it would be worth trying to install the MTECs instead. I'd rather not have the dealer take my car and royally screw something up.
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| Sticky Shifter | ansibe | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 09-15-2016 01:59 PM |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 09:20 PM |
| Shifter springs/bushings/shifter performance | Darnold | Engine, Exhaust, Transmission | 10 | 10-23-2014 12:49 AM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
