Old 07-21-2017, 03:03 PM   #15
Thanks. Just wanted to clarify that point since it has come up before and the fix was simply starting the car.
I presume you are fully stock?
If the OP says that his cousin installed a used, kart-boy short shifter, that he bought for cheap off of e-bay, ....... I WILL scream ......
Tcoat (07-21-2017)
Old 07-21-2017, 03:06 PM   #16
I doubt it from the first post but as you know it has happened before.
Armchair diagnose is bad enough but when people don't even have any details it becomes even worse.
Old 07-21-2017, 03:09 PM   #17
Lust
Drives: 2017 Subaru BRZ
Completely stock. Happens when the car is on/off. Sometimes it sticks at the point and sometimes its smooth.
Lust is offline   Reply With Quote
The Following User Says Thank You to Lust For This Useful Post:
Tcoat (07-21-2017)
Old 07-21-2017, 03:11 PM   #18
Yep bad return spring then. Pretty unusual but I guess it falls into the stuff happens category. Will be warranty.
Lust (07-21-2017)
Old 07-21-2017, 03:20 PM   #19
Lust
I have MTEC shifter springs. Are those the same springs I'm thinking of?
Old 07-21-2017, 03:24 PM   #20
Ya, but .......that's what we do best ......
Old 07-21-2017, 03:27 PM   #21
..........so, NOW you tell us that you have had the top of the transmission opened up and had messed with it ........
Tcoat (07-21-2017)
Old 07-21-2017, 03:29 PM   #22
Ummmmmmmm
Yes. Kiss warranty goodbye for the shifter.
"MTEC has released a spring shift kit for the Scion FR-S, Subaru BRZ, and Toyota GT-86. We had these installed in our silver car at 86Expo and everyone that tried the shifter could not believe the difference these made. These helps guide the shifter into the right gears. I'll let the youtube videos do the taking but for the money nothing will improve shifting like these do!"
humfrz (07-21-2017)
Old 07-21-2017, 03:31 PM   #23
humfrz (07-21-2017)
Old 07-21-2017, 03:48 PM   #24
So, after @Tcoat has drilled down ...... I would suggest that you take the MTEC springs out and replace them with the OEM springs to see if that makes the shifter all better.
Old 07-21-2017, 03:54 PM   #25
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Really?!? You're saying your car is completly stock, then you say you have installed probably the only part in all the aftermarket parts that can cause the problem you described....
Basically having a full blown race car with a stock transmission would have less chance of causing that problem than having only that little spring.
This spring is basicaly the most important part in the left/right motion of the shifter. You either didn't installed it properly, or it broke, or you inverted the 2 springs in the kit.
Put back the stock springs, and hope nothing important got damaged.
nico_rsx is offline   Reply With Quote
Old 07-21-2017, 04:07 PM   #26
Lust
Jesus christ you guys all jumped to conclusions so quickly. The car is COMPLETELY stock. I indeed HAVE the springs but I have NOT installed them. Nowhere did I ever say they were installed.
Tcoat (07-21-2017)
Old 07-21-2017, 04:12 PM   #27
In the context of the prior questions this makes it seem like they were installed.
You could try installing them and see if that fixes it but I personally would take it in and have it checked first.
Old 07-21-2017, 04:14 PM   #28
Lust
I can kinda see how one may get confused but still... in the previous post I did say completely stock. My follow up question was going to be if it would be worth trying to install the MTECs instead. I'd rather not have the dealer take my car and royally screw something up.
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
Sticky Shifter ansibe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 09-15-2016 01:59 PM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-23-2014 12:49 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
