Old 07-15-2017, 08:45 PM   #15
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by alex.s View Post
It seems like it gets to a certain point and gets noticably worse though. Not in this photo. Don't have a photo of it. Can it fold all the way over to where the bead is hitting?
Sent from my Nexus 5X using Tapatalk
It gets to the point where the tire can no longer can maintain adhesion, which is why it feels worse - the tire is on marbles at that point as it scrubs the tire across the asphalt.. You won't be on the bead - you'll just be at the point where the compound can no longer hang on....in part, due to the tire flexing. Play with the pressure and see if things change at the same point of the track. Ultimately though, you're eventually going to want to upgrade your tires. You'll be pretty amazed at what just a tire make/model change can do for this car.
venturaII is offline   Reply With Quote
Old 07-15-2017, 08:49 PM   #16
venturaII
venturaII's Avatar
Originally Posted by OND View Post
Are the sidewall marks going all around the tire? It might just be from rubbing a kerb maybe?
I'm assuming he curbed the tire a bit; the wear at the edge of the tread looks about as expected for this tire and stock-ish pressures
Old 07-15-2017, 09:05 PM   #17
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
Otherwise, the wear on stock tires look like what I had with mine. Stock 0 camber and the hard tire compound is a bad combination.
Add some heat and overdriving and you will get this:
http://www.ft86club.com/forums/showthread.php?t=112935
All the way around. Could be the curb
alex.s is offline   Reply With Quote
Folding down the backseat. Sparda29 Issues | Warranty | Recalls / TSB 18 04-07-2017 09:07 AM
Power folding mirrors trinitron Cosmetic Modification (Interior/Exterior/Lighting) 60 08-17-2016 01:00 AM
50/50 rear folding seat Mars2 Scion FR-S / Toyota 86 GT86 General Forum 11 12-18-2012 11:32 PM
Fr-s Power Folding Mirrors? Koolkiid Cosmetic Modification (Interior/Exterior/Lighting) 19 09-15-2012 01:31 AM
Power Folding Mirrors? migle BRZ First-Gen (2012+) — General Topics 30 04-20-2012 11:35 AM
