Old 07-16-2019, 10:12 PM   #15
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
I just had my 30000 mile service done last week. This is a 2015 Scion FRS. According to my Maintenance Schedule, I should have the engine oil and filter changed, the cabin filter replaced, the air filter replaced, the tires rotated and the brake fluid replaced. I replaced the cabin filter and engine air filter myself. No problem. I had the shop where I purchased my all season tires rotate them for me. No charge, because I bought the tires there. So far, no problem. I had the dealership replace the oil and filter for about 70 bucks, and the brake fluid replaced for 140 bucks. Total price - $210. I called the local Subaru dealership, and the price was essentially the same. Here's the problem - as they were buttoning up the whole thing, the service adviser calls me and said that the technician said I should have the rear differential fluid replaced. He said, "after all, it's a rear wheel drive vehicle, and we always suggest a fluid change at 30000 miles".
This, in my mind is a total up-sell. After I retired from my job, I worked part time a couple of days a week at the local Lexus dealership. I was a valet - I would drive the customer's car to the Service Manager, who would direct me to give it to the next Technician. This was a great little job for me, but I found out that the Service Department would give bonuses to Technicians that could "up-sell" a customer for more work done at that same time.
My question is this: do the twins really need a rear differential fluid change at 30000 miles? I can see it at, maybe 60000 miles, or if there were severe conditions that the car was subjected to. I don't see the service even covered in the Maintenance Schedule.
Finally, I know that there are some of you out there that say I'm wasting my money having such simple things done at a dealership when I could easily do it myself. I just want to head you off at the pass - I'm 65 years old, and I have done oil and filter changes before some of you were even born. That said, I'm just too old and tired to do it myself now.
Anyway, your thoughts on a rear differential fluid change at 30000 miles would be appreciated.
Oh, after I declined the extra service the Service Adviser said the fluid just "looked a little brown" and that it should be fine for a while....
Last edited by winstonscifi; 07-16-2019 at 10:16 PM. Reason: I'd like to add something else
winstonscifi is offline   Reply With Quote
The Following User Says Thank You to winstonscifi For This Useful Post:
Will BRZ (07-16-2019)
Old 07-16-2019, 10:55 PM   #16
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Also interested in this. Dealership is quoting $400 for everything since it's an automatic. I can get it a bit cheaper if I decline a couple things, but as mentioned above, it includes lots of services. I'm definitely declining tire rotation as I'm getting new ones next month. I know for a fact, however, that it needs most of the services.
Does anyone know how often (or if) automatic transmission fluid needs to be changed? I know it's at 30,000 for manuals, but I've heard automatics "work differently". I'm asking because it has to go in for the transmission pan gasket to be replaced (waiting on the part). Not sure if I should ask them to just go ahead and change the fluid in there as well. What do you guys think? Just want to get everything sorted out so I can put a damn catback on or something lol
Will BRZ is offline   Reply With Quote
Old 07-16-2019, 11:04 PM   #17
86TOYO2k17
Drives: 2017 toyota 86
Have your kid or grand kid do it. Just as easy as an oil change, but the fluid is about half the cost and you don’t need a new filter. 30$ DIY. Maybe 50$ for them to do?
At 30k it wouldn’t be a bad idea. The first time it ever gets changed your magnet will be completely coated in shavings as the first 1k miles of a diff or gears in general does the most wear.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
winstonscifi (07-16-2019)
Old 07-17-2019, 01:51 PM   #18
qqzj
Drives: MDX, Camry
Why don't you ask around in this forum? Maybe a lot of guys can do this for you for a lot less. Yes, it is a good idea to change rear diff fluid if you want to keep it for a long time. After the first change, there will be less metal shavings. So next change can be 40 or 50k later.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 07-18-2019, 02:01 PM   #19
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
ATF interval is 60k miles. If you do any hard driving (track or lots of mountain runs 30-45k seems to be the real life of the fluid). If it isn't shifting rougher then normal stick to the interval in the owner's manual. If the oil pan is coming off they're gonna have to change the fluid anyway no?
The first change on the diff will be dirty as hell at 30k miles cuz of the break in. After that if you only daily drive the car it will likely look almost new at 30k miles.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Will BRZ (07-18-2019), winstonscifi (07-18-2019)
Old 07-18-2019, 05:12 PM   #20
Will BRZ
Drives: 2015 BRZ
You’re right and I’m an idiot lmao didn’t think about that
Dropped it off today and picking up Monday, hopefully. It is shifting a little bit rougher, especially when in manual mode. I’m assuming it’s because of the leak but we’ll see. Kinda nervous but just glad it’s covered by warranty. Hope it’s nothing serious.
The Following User Says Thank You to Will BRZ For This Useful Post:
finch1750 (07-18-2019)
30k mile service - over limit? kgc Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-08-2015 03:27 PM
30k mile service Mossyjaw Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-04-2015 02:28 AM
15,000 mile service cost at Subaru? paiceyfan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 01-29-2015 04:42 PM
30,000 mile service goke186 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 10-11-2014 10:52 PM
50,000 mile check in. Superhatch BRZ First-Gen (2012+) — General Topics 38 12-24-2013 05:57 PM
