Old 05-19-2017, 08:09 PM   #15
steve99
Originally Posted by Amputechture View Post
Maybe my assumption is wrong on this, but I vaguely remember someone telling me that the OFT crowd's boost cut implementation is a fuel cut past a certain MAP value. You know more about this than I would...what is the advantage of fuel cut versus lowering duty cycle of the solenoid to go back to WG pressure? I could be wrong but it seems that cutting fuel would elevate combustion temps and open the door to detonation.
Yes oft overboost is complete fuel cut based on map pressure reading. Their is a hysterusis and yes its complete feul cut so very abrupt but will save engine. Complete fuel cut is ok, its an extended lean condition that is a big problem.
Yes you could adjustt the waste gate duty cycle electronicly to adjust boost but you would be obly able to limit boost to the waste gate spring pressure. Ie the boost control can be increased above the waste gate spring pressure but not below.
Also overboost protection is mainly their to guard against a wastegate failure or malfunction causing too high boost, so you want an independant system as a failsafe.
Ecutek guys will just use a custom maps to do similar process but you can get more adjustability and fancy
Old 05-19-2017, 08:27 PM   #16
jerseymike1966
Drives: 2014 BRZ
Originally Posted by Sportsguy83 View Post
The solution is simple. You get a tune from an Ecutek tuner that does not lock their tunes, because you paid for it and its yours. Such fancy unicorns do exist, best of both worlds.
It's called HRI Tuning (James Martin). Contact him.
Oh cool. Good to know.
jerseymike1966 is offline   Reply With Quote
The Following User Says Thank You to jerseymike1966 For This Useful Post:
Sportsguy83 (05-19-2017)
Old 11-24-2017, 12:15 PM   #17
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Besides tuning..... is the OFT, i guess, good enough to make accurate readings on AFR, Boost, Oil pressure through 3 bar map sensor for JDL kit? or am I better of getting getting wideband (aem) or other gauges?
May be a little bit of thread jack but its slightly related
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 11-24-2017, 12:25 PM   #18
steve99
OFT will read/log data from the standard sensors available on car as good as anything else.
The car doesn't come with an oil pressure sensor so you need to provide your own . (its only a simple switch at about 2 psi to light the dash light should read replace engine light)
car only has oil temp sensor
the stock o2 sensor can be recalibrated to read richer afr quite successfully down to about 10.5
If you want to implement automatic failsafes in tune for oil pressure loss and afr then you will likely need ecutek.
oft only has overboost cut based of map sensor.
different map sensor just need to be scaled in tune can do that with all tune systems
ShadowReaper (11-24-2017)
Old 11-24-2017, 12:36 PM   #19
ShadowReaper
Indulgent Tormenter
I am buying an Ecutek tuning bundle from my tuner...probably today
So Im not actually tuning the kit through OFT. I have been planning on selling the tablet but then I thought about all the readings the it makes, so I'm just seeing whats the better option as far as boost / afr / oil temp/ press
Old 11-24-2017, 01:48 PM   #20
steve99
oft would read boost afr and oil temp, but pressure no as it would be external sender.
you would probably be better selling tablet and buying the ecutek blutooth dongle then using the ecutek android or apple app to monitor ecu it can be set up with custom dash gauges.
tuner could intergrate oil pressure sender and failsafe cut in ecutek custom maps.
http://www.ecutek.com/ecu-connect
they could feed oil pressure signal into ecu then you could use it for failsafe and display in blutooth app
Forced Induction James The Giant Mid-Atlantic 4 03-17-2017 12:00 PM
Forced Induction HELP! surfuxalot Forced Induction 22 06-20-2015 12:56 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
