Old 04-27-2017, 04:34 PM   #15
Originally Posted by extrashaky View Post
No it isn't.
I prefer to set the temp colder than I actually want the car to be, then adjust the fan to where it's comfortable. That allows me to have different parts of my body experiencing different air temps to maximize comfort.
If you like the auto function, that's great for you. That's not necessarily best for everyone else.
Gah. No. I hate buttons on the steering wheel, especially when the vehicle gets to be ten years old and the failing clockspring starts causing random weird electrical gremlins. By putting controls on the steering wheel, you are ensuring that those buttons and/or functions will fail at some point if the rest of the car lasts long enough.
The thing has more buttons on the steering wheel than some cars have on the dash!
Old 04-27-2017, 08:15 PM   #16
nico_rsx
Drives: BRZ 2017 Pure Red, MT
When you press auto, you're in "full auto". If you manually adjust any of the controls that are automatically controlled, then you deactivate the automatic control of that function, and you switch from "full auto" to "auto".
For exemple, if you touch the vents position button when in "full auto", then you become "auto", and the car doesn't control the vents position anymore. If you adjust the fan speed, then it stay at that speed, and the car doesn't control it anymore. Once there is nothing for the car to control, then the "auto" dissapear.
Appart from the fan speed, vent position there is also the AC and recirculation button that need to be "touched" for the air control to become full manual.
nico_rsx is offline   Reply With Quote
Old 04-27-2017, 09:52 PM   #17
Esseff
Drives: 2017 BRZ Ltd White
Oh, and this:
It's clearly labeled as the "OFF" button. Why the hell would you expect the "OFF" button to turn it on? Do you walk up to the "OUT" door and beat your fists against it because it won't let you in?
On 99% of devices the Off button also does On. You would also assume so, considering there is no other On button (even the AC button doesn't turn it on). And where does it say On, on the Fan dial? Which, apparently is how you do turn it On.
And you are right... my purpose was to highlight the illogical, unintuitive nature of the system.
ACs give me headaches so I use them minimally. I prefer the fan, and regularly adjust it or I have the whole thing switched off and use the windows.
And, manually adjusting the fan control does NOT turn off Auto mode! It turns off Full Auto but not Auto. Still don't know how I have managed to do it a couple of times.
Esseff is offline   Reply With Quote
Old 04-27-2017, 10:06 PM   #18
I sometimes miss the simplicity of my old cars!
Intuitive as hell:
8RZ (04-28-2017), Gil Scott Heron (04-28-2017), humfrz (04-27-2017)
Old 04-27-2017, 10:29 PM   #19
humfrz
Intuitive as hell:
.......and, here was the A/C and its control knob ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Gil Scott Heron (04-28-2017), spike021 (04-27-2017), Tcoat (04-27-2017)
Old 04-27-2017, 11:54 PM   #20
Esseff
Well, after more investigation I have finally worked out how to turn off all the Auto modes... you switch the Recirculate button on then off.
Obvious... NOT!! (yes, sarcasm intended)
Old 04-28-2017, 12:00 AM   #21
nico_rsx
See my post above, I explain it all.
The Full auto mode control 4 functions (fan speed, vents positions, recirc and AC). If you manually adjust any of those function you go to auto mode instead of full auto, and the car control the 3 remaining functions (plus the temperature). You need to manually adjust all 4 to remove completely the Auto mode.
Old 04-28-2017, 01:52 AM   #22
humfrz
Congratulations!
Yep, back in the day ..... it was easier. If you pushed the handle under the dashboard, lots of fresh air came in ..... pull it up, fresh air stops.
The heater was 3 zones ...... depending on which little door(s) you opened .... shut them all, no heat.
humfrz
Old 04-28-2017, 02:11 AM   #23
spike021
spike021's Avatar
humfrz
Is that a radiator at the bottom middle/right area?
spike021 is offline   Reply With Quote
Old 04-28-2017, 02:48 AM   #24
Gil Scott Heron
Drives: '17 Asphalt 86
When the cars are fully autonomous, you will be able to travel to your programmed destination and simultaneously watch an instructional video about operation the HVAC system.
My first ride (1951 Ford F-1 truck) had the good ol' cowl vent as depicted in humfrz's picture, as well as the radiator in the passenger footwell for heat.
Gil Scott Heron is offline   Reply With Quote
The Following User Says Thank You to Gil Scott Heron For This Useful Post:
humfrz (04-28-2017)
Old 04-28-2017, 03:30 AM   #25
humfrz
Back then, most heaters were mounted on the inside of the firewall. Within the heater unit was a small radiator like core. The air was forced, either by a fan or convection, from the top, through the core out the vents.
Further back in the day, the exhaust manifold was shrouded and the shroud directed heat off the manifold into the cabin. A dirty trick during the winter, was to lay a slice of limburger cheese on a cold manifold ....... ya get the drift ......
I gotto go ...... feed the horses some oats and hit the hay ... ZZZZZZ
humfrz
Old 04-28-2017, 03:33 AM   #26
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
What a stupid mess.
PetrolioBenzina is offline   Reply With Quote
Old 04-28-2017, 03:36 AM   #27
humfrz
Originally Posted by PetrolioBenzina View Post
What a stupid mess.
What's a stupid mess ?? ........
humfrz
spike021 (04-28-2017)
Old 04-28-2017, 04:33 AM   #28
paulca
Drives: Toyota GT86 Coupe Red (UK)
I remember fully manual climate controls.
Get in the car, check it on heat, turn the heat up to max, turn the fan up, EUGH! Freezing cold air... turn the fan back down. Drive for a while. Turn the fan back up, EUGH! Still freezing, turn the fan back down. Repeat at least twice until there is warm air, then turn the fan way up.
10 minutes later it's too warm so I start reducing the heat and the fan. Then it's too chilly so I readjust. Over and over. Switching from Window to Window and feet to feet as the window defogs.
What I like about auto is it does all this for me.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT MudithJ Cosmetic Modification (Interior/Exterior/Lighting) 3 08-04-2016 11:13 AM
Subaru BRZ - Dual Zone Climate Temperature - Wrong? Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 21 03-22-2015 02:11 PM
Tiny amount of engine oil smell passing through aircon? Mim Issues | Warranty | Recalls / TSB 9 01-18-2015 01:11 PM
AFR's Danger zone!? Brick Software Tuning 20 02-24-2014 07:14 PM
DRL + "Eyebrow strip" dual operation? Weeber BRZ First-Gen (2012+) — General Topics 3 11-26-2013 02:35 PM
