Old 04-21-2017, 02:13 PM   #15
humfrz
Originally Posted by snk828 View Post
2011 production model, the engine vibrates too.
hmmmm......I haven't heard of a "2011" FR-S.
When was your car built .. ??
humfrz
Old 04-21-2017, 04:24 PM   #16
snk828
snk828's Avatar
Drives: raven FRS
How is the engine running, as far as putting out power .. ??
Any codes thrown .... ??
Back-in-the-day ....... I would have suspected a fouled spark plug.
humfrz
It's running good, engine has some vibration but nothing major. It doesn't feel like power lost anything like that
snk828 is offline   Reply With Quote
Old 04-21-2017, 04:24 PM   #17
snk828
snk828's Avatar
Drives: raven FRS
Is it completely stock?
Not stock, header , exhaust and OFT tuned
Old 04-21-2017, 04:27 PM   #18
snk828
snk828's Avatar
Drives: raven FRS
Could be fine, OP is it your first sports car?
Not the first sports car , my first car is 91 MR2 and then a Honda Del sol. I also drove couple of my friend's BRZ and Frs. They don't have that steering wheel vibrations .
The Following User Says Thank You to snk828 For This Useful Post:
strat61caster (04-21-2017)
Old 04-21-2017, 04:28 PM   #19
snk828
snk828's Avatar
Drives: raven FRS
Originally Posted by Sarlacc View Post
I would take it in to a dealer ASAP!
I always thought they didn't start production until 2012.
Does your VIN have a B as the 10th character? as in JF1ZxxxxxBxxxxxxx
If it's a C it means it was assembled in 2012.
I have header and tuned , dealer won't take care of my car anymore unless I take it off and reflash back to stock tune.
Old 04-21-2017, 04:40 PM   #20
Has it always done it or has it changed somehow? Could be a result of the header and tune.
Old 04-21-2017, 05:24 PM   #21
humfrz
Well, @Tcoat ferrets out the possible cause.
I'd suggest you check all of the exhaust parts to see if any are rubbing (or even close) to any part, that is even remotely connected to any part of the steering mechanism.
If that don't work, as Tcoat suggested, check the tune to see if you can smooth out the engine.
humfrz
Old 04-21-2017, 06:48 PM   #22
snk828
snk828's Avatar
Drives: raven FRS
humfrz
I just drive my car for 15 minutes, I pay extra attention to the vibration from the steering wheel , actually I can feel my whole car is shacking. Now, I think the whole vibration is come from the engine, I will change my tune back to stock and get a feel from it again. I hope it's just the tune , then I can get a better tune to fix that. I also realize The car shacks a lot when I turn on the AC since the RPM will drop down and come back up to 700. Its more obvious in the morning when its hot around 90F outside,it has less vibration at night when it's cold.
Tcoat (04-22-2017)
Old 04-21-2017, 06:57 PM   #23
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Does it shake when driving, or only when idling and/or standing still as you said in your first post?
Old 04-21-2017, 06:59 PM   #24
snk828
snk828's Avatar
Drives: raven FRS
Only shake when idling.
Old 04-21-2017, 07:16 PM   #25
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Ok. If you stand in front of it with the hood open, do you see the engine shake?
Old 04-21-2017, 07:55 PM   #26
snk828
snk828's Avatar
Drives: raven FRS
Yes , it does shake when the AC kicks in . I think that's normal for AC on.
Old 04-21-2017, 11:43 PM   #27
May be as simple as bringing the idle up a couple of hundred RPM at idle. If it is shaking more when the AC comes on it is struggling to keep running.
Old 04-22-2017, 12:09 AM   #28
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Mine twitches a little sometimes when the AC kicks in at idle. The idle RPM fluctuates a little, too.
I seem to remember old threads about it; consensus was that it's normal, I think?
However, my old Legacy (with a similar Subaru flat 4 in it) got it worse.
It flashed dash lights and even stalled when the AC kicked in at idle.
The dealer fixed it by tickling the throttle body and resetting the ECU.
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-07-2017 12:20 AM
My steering wheel is stuck: Cusco steering wheel norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 4 01-01-2017 05:48 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 07:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Vibration feedback through steering wheel. Jayde Issues | Warranty | Recalls / TSB 5 07-25-2013 11:19 AM
