Old 02-27-2018, 07:51 PM   #15
vijay.dy06
Drives: Red BRZ
Originally Posted by 15limited View Post
Anybody have luck finding rotors to eat up the extra pad hangoff? I'm having a hell of a time even finding 08+ sti hat offset to put on a slightly larger disk.
Closest one that I've found is a g35 that has the Brembo package. Rotors need to be redrilled of course, but I have not confirmed if the Brz brake shoea will fit.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 02-27-2018, 08:00 PM   #16
15limited
15limited's Avatar
I don't even have the oem e brake shoes anymore but I believe I'll have to retain the offset so it's compatible with caliper offset. I've found Wilwood disks to run a 2 piece rotor that are the right size just can't find the hat to pair it with .
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-28-2018, 10:38 PM   #17
etc
Drives: '13 FRS
Originally Posted by Skeneypoo View Post
On the rear rotors, if I just slotted the holes on the mount for the calipers about 5mm, allowing the caliper to sit lower on the disk, would I have any other issues with clearance?
ya, I am pretty sure it would hit the hub, I don't think there is much space there at all. I also don't think there is enough extra metal to cut the slot into (nor can I think of a good way to cut it, it is steel and pretty thick).
etc is offline   Reply With Quote
Old 03-21-2018, 08:38 AM   #18
15limited
15limited's Avatar
So, attached is a cutaway of the 08+ Sti rotor, I believe it's DBA's 4000 series. If I found a disc that is 5 mm longer in diameter, and a hat with 4mm less offset I believe that would resolve using spacers and pad hangoff, unless you guys can think of anything that might interfere? Name:  dba_2655_cat.jpg
Old 03-21-2018, 01:03 PM   #19
jamal
jamal's Avatar
Drives: Legacy GT
Is there some reason you don't want to use STI calipers, which bolt right on and work with the sti rotor?
jamal is offline   Reply With Quote
Old 03-21-2018, 01:44 PM   #20
15limited
15limited's Avatar
From what I've read it doesn't help the bias with ats brembos up front
Old 03-21-2018, 06:02 PM   #21
jamal
jamal's Avatar
Drives: Legacy GT
The stock sti brembos do offer a little more rearward bias than the stock brakes, but you're right it is not a huge amount.
Stock brakes use a 290mm rotor and 40.5mm caliper piston
08-17 sti brembo have a 316mm rotor and 40mm pistons
My math for bias gives the following
stock BRZ: 68.3 : 31.7
ATS fronts: 69.6 : 30.4
ATS f, sti r: 69.0 : 31.0
Biasing starts out with equal pressure front and rear then EBD reduces rear brake pressure as needed. The stock BRZ is the most rear-biased Subaru setup with the 06-07 wrx 4/2 pots a close 2nd.
Old 05-11-2018, 10:13 AM   #22
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Anyone have any updates on this? I'm compiling my last few parts for my front ATS swap and i'm still exploring what I want to do with the rear.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 05-12-2018, 08:56 AM   #23
15limited
15limited's Avatar
It works! I wasnt able to get In to contact with anyone who has extra spacers so I found some machine head washers that were very close and used those. I would reccomend a new pin kit and maybe seals depending on how the calipers look when you get em
Old 05-14-2018, 08:06 AM   #24
blackfireball5
So you just are accepting the small amount of overhang in the pads?
Haven't sourced a rotor that fits them exactly?
Wheelwell Profile
Old 05-14-2018, 08:33 AM   #25
15limited
15limited's Avatar
Correct, I inquired about a few custom spec 2 piece rotor sets from what seemed to be reputable companies online and still no luck. I found wilwood to have the largest library of hats and rotor rings but nothing that met all fitment criteria. If I had to find a solution however it would be finding a way to mount the caliper closer to the center, which would eat up the hangout pad and theres a small amount of unused rotor surface closest to the center. However im running a hydro, hence the extra caliper, so I just went the easiest route.
Old 05-14-2018, 10:32 AM   #26
blackfireball5
Gotcha.
What did the calipers and rotors cost you?
Wheelwell Profile
Old 05-16-2018, 06:41 PM   #27
15limited
15limited's Avatar
Gotcha.
Calipers I got used online, same as OP about $250 a pair, and rotors I think $300 for the set? DBA 4000 series drilled and slotted
Old 06-15-2018, 03:04 PM   #28
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
What setup are you running for the hydro? What bracket and caliper?
HAWAIICALIVEGAZ is offline   Reply With Quote
brake, brembo, retrofit
brake bias for cadillac caliper swap and other BBKs sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-26-2016 03:03 PM
WTB: Rear Brembo STI caliper. grostoine Want-To-Buy Requests 2 07-16-2014 05:26 PM
Custom BBK using Project Mu parts and EvoX brembo calipers jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-03-2014 05:15 PM
NEED HELP!! Messed up Rear Caliper bracket。 Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-21-2013 01:58 PM
WTB: GT86 /BRZ oem front and rear caliper kit VSpec86 Australia Classifieds 0 09-12-2012 10:07 AM
