Old 06-02-2017, 05:44 AM   #15
steve99
Originally Posted by guybo View Post
Could the OFT tune have caused the failure of the supercharger?
Difficult to imagine how any tune would effect the actual supercharger. Its external to engine, no fuel goes through it. Would think damage would be a result of lack of oil in sc or lack of maintainance or incorrect oil in sc, belt too tight causing excessive loads on bearings. Maybe foriegn object or something damaging seals and oil leaked out. Sc overreved due to small a pully, or dirt ingress due lack of air filtering or similar.
Old 06-02-2017, 08:23 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
No
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-04-2017, 07:21 PM   #17
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Lack of maintenance or incorrect oil in sc: Correct SX150 oil used; Rotrex units don't have maintenance as they are un-repairable; all pulleys, filter, and fluid were replaced upon install.
Belt too tight causing excessive loads on bearings: If the belt was too tight I would be surprised as I follow the 70hz and belt 1/2 turn instruction by Kraftwerks.
Maybe foreign object or something damaging seals and oil leaked out: Didn't see anything that would hold up this theory.
Sc over-revved due to small a pulley: I was using the 95mm pulley with 7.3k redline, this is within spec for the pulley and SC.
Dirt ingress due lack of air filtering: If that's the case I couldn't have stopped it, filter looked fresh still when I pulled it.
IMO I'm not sure what caused it to fail but I didn't rush through the install or skip any steps.
elitegunslinger is offline   Reply With Quote
Old 06-05-2017, 05:30 AM   #18
steve99
Hsha,
I wasnt suggesting that you did any of those, just thst they may be posdible causes and that the tune would not .
Old 06-05-2017, 06:07 AM   #19
elitegunslinger
Hsha,
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Your real world results when tuning your aftermarket intake Nah Engine, Exhaust, Transmission 3 08-08-2016 05:43 PM
Dyno results from R/T Tuning Greddy turbo FRS R/T Tuning NY / NJ / CT / PA 1 10-12-2013 07:38 PM
DDPR EcuTek Tuning results Illusive Engine, Exhaust, Transmission 26 02-11-2013 10:54 AM
