Old 04-09-2017, 04:45 PM   #15
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
You might be lucky.
Since cam issues are quite well known and tsb issued etc, and you don't have aftermarket header they are probably not going to suspect or look for tune.
The TSB says to replace the ecu, they will just replace it , most likely without looking any further. You will then need to get the tuner to renew you ecu licience and tune.
However tunes are easy to detect, and unfortunately flashing back to stock with ecutek still leaves the licience in ECU, which alters the CVN (checksum value number) so can still be detected, but they may not look that hard if your lucky.
My luck is so bad, but I'll still be hopeful as you said.
They've scanned and found cam issues and now fuel pump. Since they've scanned it, does that mean that they would've already detected my tune on the ecu or is it a different type of scan they need to look for to detect my tune?
Roneezy is offline   Reply With Quote
Old 04-09-2017, 11:31 PM   #16
steve99
No the scan for codes and diagnostics works exactly the same on a tuned car as stock.
They have to say try refreshing ECU, then they won't be able to due ecutek lock, or pull on cruise stalk and see map switching or read out the cvn number and compare it to the stock cvn not things they routinely do unless they are looking for tuned, but it's certainly possible to detect a loaded tune file
Roneezy (04-10-2017)
Old 04-10-2017, 09:44 AM   #17
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Kind of sounds like you made your own luck there. What were you expecting, warranty-coverage wise, when you had it flashed?
Shinigami301 is offline   Reply With Quote
Old 04-10-2017, 10:05 AM   #18
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
I could be wrong, but I think that anytime you take your car into the dealership, they enter the visit in their database. If one dealership denies warranty coverage based on your alteration of the car's ECU programming, they'll probably make a note of it and any other dealership would see that information when pulling up your car's records.
I hope things work out for you, but I'm kind of in the "you broke the warranty rules, so don't complain" crowd. Reflashing back to stock and lying to the dealership is a less than honorable path, Grasshopper.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-10-2017, 11:20 AM   #19
Riftur
Riftur's Avatar
Hello,
I have a 2015 FRS Automatic that has 28k miles on it and purchased it July 2015.
So this past Wednesday April 5th I started up my car to leave work and as I was leaving the parking garage my traction control and CEL came on. Drove straight to dealership and was told it was something of a camshaft sensor.
Something like that(not exact words). Then they cleared the code and drove it for a few miles, now a new code popped up.
This time my Fuel Pump Assembly.
They'll let me know on Monday what step they'll take next...
I fear that this is the start to a series of headaches. I know this is still covered under warranty and what not, but has anyone else gone through this?
What should I do next? Service adviser also said that with my car being lowered and having aftermarket wheels, if a Toyota rep came I'll most likely be voided for any major repairs...
Only mods I have are
Bilstein shocks and Eibach Lowering Springs
MXP Comp RS Catback Exhaust
Ambit Wheels/Super Sport Tires
Delicious Tuning flash and go stage 1
K/N Drop in Air Filter
Are they able to discover that I tuned the car? Thats really the only engine mod I have going on with it.
Just found this thread. Think it might help both of us a bit.
http://www.ft86club.com/forums/showt...highlight=Shiv
Riftur is offline   Reply With Quote
The Following User Says Thank You to Riftur For This Useful Post:
Roneezy (04-11-2017)
Old 04-11-2017, 01:59 AM   #20
Roneezy
Roneezy's Avatar
Well I got the car back and it seems to run fine.
All they did was clear the codes again and if it comes up just to go back to the dealership and they'll do whatever it is they did again.
In the end nothing happened, I hope this is the end of it but that likely wont be the case..
Old 04-11-2017, 07:18 AM   #21
Riftur
Riftur's Avatar
Well mine progressed slowly. I got some new codes this morning. u0100 and u0122. Which mean lost communication with the ECU and ECM. It did not trip the CEL though. My Torque app sees the code but my OFT does not see it. Weird huh? Edit: I know what caused the issue. My OBDII adapter caused it when working with torque. It actually happened to me once about 1 year ago. At least I think its the OBDII adapter.
Old 04-12-2017, 04:46 AM   #22
Roneezy
Roneezy's Avatar
Oh, well even if it was another thing thanks for at least trying to provide information!
I appreciate that.
You and I are on the same boat lol.
The Following User Says Thank You to Roneezy For This Useful Post:
Riftur (04-12-2017)
Old 04-17-2017, 07:20 AM   #23
paulca
Drives: Toyota GT86 Coupe Red (UK)
This always worries about ECU flash tunes. In a modern car, everything is controlled by software in the ECU. As a software developer I am thankful I do not work in the auto-motive department as the software quality controls and testing requirements are huge. Almost every line of code has to be documented, justified and defined for testing and potentially legal cases later on if they are suspected of causing death or serious injury... yes, it's that serious.
Then you hand over your car with multiple-million dollar developed and tested software to a bad street greasy tuning shop who flash it like it's an Android phone!
Scary stuff.
The downside is, if you fit aftermarket parts you might not get the full benefit from them without a flash. I believe you can have some parameters tuned more safely, but a full ECU flash sounds ... well... just dumb IMHO.
If I was Toyota/Sion I would tell you to walk.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
The Following User Says Thank You to paulca For This Useful Post:
Tcoat (04-17-2017)
Need advice - major problems with Hotchkis kit GSX-R35 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-18-2016 03:48 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
[Power Steering/Electrical/Warranty] Problems, could use some advice. Ajax969 Issues | Warranty | Recalls / TSB 7 07-26-2015 08:01 PM
BRZ/FRS problems... jdmgevo Issues | Warranty | Recalls / TSB 19 08-07-2014 11:54 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
