CANADA Canada
Old 07-18-2012, 09:59 AM   #15
2pt5RS
Berz
Originally Posted by RandomHero View Post
The door will open but if it does freeze I think you will risk tearing the seal. No idea on a price for that but at least you wont get trapped in your car? lol I like the idea of silicone lube on the seal sounds like a good plan. Someone told me WD-40 works also?
WD-40 is water based, so it could freeze just like the water.
2pt5RS is offline   Reply With Quote
Old 07-18-2012, 10:08 AM   #16
HunterGreene
Hail Magnet
HunterGreene's Avatar
Not according to their website--its petroleum based. Not sure where you got your info.
As far as a fix for frozen windows, I've had doors frozen shut before, and usually a few light love taps along the frame is enough to break it free. Remember, the rubber door gaskets aren't frozen solid, they should still flex enough to pop the ice free. However, parking in a garage is an excellent solution.
Old 07-18-2012, 10:14 AM   #17
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
No WD40 is a water displacer, actually that's exactly what the WD stands for (40 is the number of formulas they tried).
Nerd moment warning: it was originally used to coat ICBMs so water/condensation wouldn't settle an cause oxidation. Google it if you don't believe me.
Sent from my Galaxy Nexus using Tapatalk 2
Ricepuddin is offline   Reply With Quote
Old 07-18-2012, 11:08 AM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
WD-40 will leave a dirty line in things that contact the rubber seal, ie: your clothing. Also, if it contains petroleum distillates, which I believe it does then you might eventually cause deterioration to the rubber seal. It will also cause the rubber to pick up dirt.
Silicone lubricant spray is clear and inert w.r.t. reacting with the rubber seal chemically. I have owned an Integra with frameless windows and I can see a door seal freeze as a real concern when you can't open the door. Al least with my xB the only issue was opening the window itself. I got this fix from another forum and it works. My impression was that the xB might not have received very thorough cold weather testing, or perhaps an oversight was made to limit additional cost. The silicone also gives the rubber a nice look, like Armour All.
Old 07-22-2012, 08:24 PM   #19
hotmetal
hotmetal's Avatar
Drives: 2013 Toyota Camry SE
I've been through 10 Canadian winters in my 2002 Celica, with the same frameless window setup. I have never had a frozen door/window issue, and the seals are still good even in a touchless car wash. Haven't had to think twice about it...
That said, if you have to wash the car outside in subzero temps, turn the car on with the heat on when you rinse it and then once dry enough drop the windows an inch like you suggested. Same thing after going through a touchless wash, just drive with them down an inch for a few minutes...
LOL to the guy climbing into the 91 GTS through the trunk... I can only imagine watching someone my size (6'4 - 240) try and climb through the FR-S trunk into the cabin...
2013 Toyota Camry SE 4-cyl - Current ride.
2002 Toyota Celica GT - Traded after 345,000 kms
hotmetal is offline   Reply With Quote
Old 07-22-2012, 09:54 PM   #20
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Originally Posted by Saibot View Post
no, if its steaming hot, pour it on, get in ur car and turn those windsheild wipers on.
sure it'll freeze other parts but now you dont need to get ur windsheild wipers unstuck; and your window(s) will be clear.
1. get a bucket
2. go to bath tub
3. fill with steaming hot water
4. pour dat on the car
5. no need to scrape ice or ANYTHING anymore.
Saibot if you've done this in the past you're one lucky son of a gun. If there was the slightest crack or stone chip in your windshield the rapid thermal shock would of split your windshield right across.
DO NOT POUR HOT WATER ON YOUR FROZEN WINDSHIELD YOU RUN THE RISK OF CRACKING IT
if your windows/doors/locks are frozen solid there's keychain sized bottles of de-icer liquid you can buy to spray on and melt the ice....but the only time I've every had my doors frozen solid was either after washing it in the winter and not drying it properly or if it was raining and it flash froze overnight. which happens very rarely in the middle of winter.
jimmillion is offline   Reply With Quote
Old 07-22-2012, 11:24 PM   #21
delsol97
Drives: none
LOL
This is hardly the first car with a frameless window.
delsol97 is offline   Reply With Quote
Old 07-23-2012, 07:20 AM   #22
s2kdrew
Drives: 2013 hot lava FRS
Same thing for my S2000, I could still open the doors after freezing rain but can't open the windows unless I had the heat up for a bit. But don't forget our car needs the window goes down when we open the door. Just wonder how are we going to open the door or shut the door if windows don't go down. Since they have the window goes down to get into the rubber seal.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 07-23-2012, 07:29 AM   #23
brianc
OCD
brianc's Avatar
I've found that applying some type of lubrication to the seals helps.
OCD - obsessive car detailer!
brianc is offline   Reply With Quote
