#15 | |
#16 | |
Drives: 2005 Toyota Camry
If you go Ace from header to exhaust (assuming you are including front pipe), wouldn't that defeat OP's purpose of reducing noise and drone? Tell me how a full header/OP/FP setup with no resonators would sound with a catback? Any catback? -alex |
#17 | |
The most important factor when it comes to sound on our cars is the size of the resonator. If you have straight-through components on the header or front pipe side, the exhaust system must overcompensate for this lack of sound suppression. If you ran straight through with stock exhaust, it will sound like a weird buzz or rattle when you are under WOT. If OP wants to retain a catalytic converter, the options are limited to catted header or catted front pipe. Given that most of the catted front pipes on the market don't have a large enough resonator, the choices are very VERY limited.... so Apex'i or HKS would be a good start considering a high quality system. If OP doesn't care about a catalytic converter, the best bang for buck would be something like Tomei UEL (or equivalent) and Fujitsubo front pipe (or equivalent). I only suggest Fujitsubo because the resonator is large enough to do something. But if we are limiting the discussion to people with actual experience, then yes, only one person's opinion matters. -alex |
#18 | ||
Not a troll
See above. But, again, you must know better than myself and ACE. From ACE's product description of their catback "Designed for <90db at 6,000rpm measured 30ft and 30* offset withh full Ace catless system" |
#19 | |
-alex |
#20 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#21 | |
I knew they were developing it but didn't know it was for sale already. Probably useful if these things were made clear. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Clipdat (03-08-2017) |
#22 |
BoostedBRZ
Drives: Turbo BRZ
I have a tomei uel, JDL 3 inch ultra quiet over front pipe, and the 3 inch perrin resonated. highly recommend. anything three inch that has an N1 style muffler will be loud as hell.
| Recommendation regarding exhaust and headers | reynierpm | Engine, Exhaust, Transmission | 71 | 03-25-2017 12:37 PM |
| Exhaust recommendation around $400 | hosfordryan | Engine, Exhaust, Transmission | 15 | 11-04-2015 06:40 PM |
| Exhaust recommendation. | GerryL | Engine, Exhaust, Transmission | 16 | 10-31-2015 09:12 PM |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 10:08 PM |
| exhaust and intake recommendation | jp_r6 | Engine, Exhaust, Transmission | 14 | 12-29-2013 04:25 PM |
