Old 02-24-2017, 03:36 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by curiosul View Post
Actually thinking about getting one. I test drove one (see my impressions here) but I didn't have time to notice/check everything.
Questions:
1: What rpms do you get at 70 mph?
There's no youtube video of someone cruising (or even accelerating) in 6th gear. Maybe some one can post a youtube video of cruising, 1/3 throttle accelerating from 60 and WOT accelerating from 60 in 6th gear?
I'll look next time. Sixth is perfectly usable, more so than in the manual FR-S.
2: How accurate is the speedometer (compared to GPS)?
All the old cars I've had were doing around 67 when 70 was indicated.
The newest car I have (a 2016) is SPOT ON.
Why is this an issue?
3: What kind of cruising MPGs do you get (flat road, no AC, 70mph, stock)?
Approx 30 mpg at fillup, which is all that matters. The MPG display is utterly useless for comparisons.
4: How accurate is the indicated fuel consumption?
Why does this matter? Again, a useless indicator for any real-world use.
5: For "early adopters" (people who bought it in early fall) did you notice a big difference in fuel consumption between summer and winter blends of gas?
No.
6: How do you get the high beams with the new headlights?
The switch on the stalk like usual?
Is there a separate bulb (that I can't see in pictures) or is the whole assembly twisting up?
Is it blinding for the incoming traffic or just a tad brighter than low beams?
It's a high-beam, how would it be different? I get flashed often when on low.
Thank you!
Buy the car, but if these are actual concerns for you, you will go mad once you have the thing.
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Tcoat (02-24-2017)
Old 02-24-2017, 03:54 PM   #16
Originally Posted by Borchert97 View Post
I always use the electronic speed warning signs around the city to gauge a vehicle's accuracy. As OP said, a lot of vehicles do understate their own speed. I'll go by an electronic sign indicating, for example 25 mph, at 32 mph, but the sign tells me I'm going 29 mph.
Again not a great way since they can vary even more than GPS or the speedometer. Those signs are just designed to be in the general ballpark and are not a precision device.
Old 02-24-2017, 04:40 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Shinigami301 View Post
Certainly did not mean to irritate you with that, sorry if I did.
Don't worry. Tcoat's just a d!ck.
Old 02-24-2017, 07:58 PM   #18
humfrz
Ultramaroon ....... shame on you .......
@Tcoat is NOT that way ALL the time ......
humfrz
Old 02-24-2017, 08:05 PM   #19
Ultramaroon
not playing cards
Ok, he's not a d!ck. That's just a very tiny part of him.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Cole (02-24-2017), daiheadjai (03-13-2017), humfrz (02-24-2017), nextcar (02-26-2017), PandaSPUR (02-28-2017)
Old 02-24-2017, 08:08 PM   #20
Cole
Not a troll
Cole's Avatar
LOL
The Following User Says Thank You to Cole For This Useful Post:
Ultramaroon (02-24-2017)
Old 02-24-2017, 08:08 PM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
This is not the car you are looking for.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
krayzie (02-25-2017), Tcoat (02-25-2017)
Old 02-24-2017, 08:15 PM   #22
humfrz
@curiosul I suggest you consider what he just said.
This car makes all kinds of funny little sounds and moves that take some getting used to.
After reading some of your other thread, it seems that your expectations may be too high for any different car in this price range.
IMHO, this car does very well for what it was intended to do for the price.
If you're looking for something more "tossable" and one with the road, within the same price range .......I too suggest you check out a NC Miata.
humfrz
Cole (02-24-2017), Ultramaroon (02-24-2017)
Old 02-25-2017, 11:16 PM   #23
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by DM7 View Post
Tire wear will affect your speedometer reading as well. Going from a brand new tire with 9/32" tread depth to a bald one with 2/32" multiplied by 2 is 7/16" of change in diameter. Speedometer indicated speed will be higher than actual speed. Going from one tire make and model to another will change diameter as well even if they have the same size specifications.
Want accurate speed? Snapchat speed filter is the only way to go.
Tire wear/tire size, etc will effect actual speed, but has no effect on indicated speed.
The speedo is actually a tachometer reading the RPM of the output shaft of the tranny. Any changes from the tranny on back will not have any bearing on what is indicated on the speedo.
You could mount a pair of 20s on the drive wheels, or a pair of 10" tires on the drive wheels...the speedo will still read the same relative to engine RPM.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
Old 02-25-2017, 11:43 PM   #24
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The high beams are a separate bulb just like the old ones. It will blind oncoming traffic exactly the same any other high beam on a car.
High/low beams are all one unit on the 2017.
The Following User Says Thank You to Andrew025 For This Useful Post:
Tcoat (02-25-2017)
Old 02-25-2017, 11:55 PM   #25
Probably the least of the concerns with this thread really.
Andrew025 (02-25-2017), Ultramaroon (02-26-2017)
Old 02-25-2017, 11:58 PM   #26
Andrew025
Andrew025's Avatar
I just calls em like I sees em
¯\_(ツ)_/¯
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
Tcoat (02-26-2017), Ultramaroon (02-26-2017)
Old 02-26-2017, 12:28 AM   #27
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
1. about 3k rpm give or take
3. Should expect EPA numbers for freeway
4. It is optimistic by at least 10%
5. No, traffic conditions have a bigger impact.
Originally Posted by DandoX View Post
In my '13 FRS at sea level it is about 3200 rpm, maybe 3100 but around there.
Your elevation will impact this.
And you guys are aware that the final drive ratio varies by country, and in the US at least was changed for manual transmission cars in 2017, right?
nextcar is offline   Reply With Quote
Old 02-26-2017, 12:32 AM   #28
nextcar
You sure about that? Not the wheel speed sensors used by the ABS system?
manual/stick shift dalli BRZ First-Gen (2012+) — General Topics 48 04-08-2016 01:01 AM
A quick video tutorial on how to drive a stick shift:) Andre Suwuh FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 03-17-2016 08:53 PM
Shift knob vs a shift stick? DVNARC Cosmetic Modification (Interior/Exterior/Lighting) 23 09-13-2015 08:33 AM
Driving stick shift (twins vs any other sticks) Drakelee117 BRZ First-Gen (2012+) — General Topics 60 05-28-2015 10:18 PM
Stick shift school in Houston? nitewolfgtr Southwest 6 09-07-2013 02:32 PM
