Old 02-15-2017, 05:03 PM   #15
kch
Senior Misanthrope
kch's Avatar
When I pushed the "S" button on my old Mini Cooper, it sharpened throttle response and added weight to the steering, both of which were lovely. I pretty much only drove with that mode on. Now my question is, does our car do anything else apart from relaxing the traction control a bit? Cause I do find the throttle response a little sluggish and find myself wishing there was an "S" button.
Nope, it only changes TC and VSC settings. Steering feel and throttle response are constant.
Old 02-15-2017, 05:34 PM   #16
Icecreamtruk
Drives: Track preped NA FRS
As a side note to this, since it got me thinking, staggering pads the "wrong" way (more pad rear than front) actually improves braking distances on ice quite a bit. It has the added effect of getting the car sideways if you are braking while doing a light turn (vs plowing straight on with same pad, or front stagger), which I find better/safer but most people would find "undrivable" or "dangerous".
Old 02-15-2017, 11:25 PM   #17
renfield90
The Stig's German cousin
Originally Posted by Kodename47 View Post
You can get the car very out of shape with just the TCS fully off, why do you need the pedal dance? On track I can maybe understand but the main thing I get from the threads is that it stops the TCS turning back on if the car leaves the ground and disables EBD. Neither of these are necessary on the road so the button hold should be enough IMO.
Certain track guys prefer that the brake system did not intervene for them to keep the car pointed straight. By and large EBD does that by making sure that wheels with weight transferred off of them aren't braked as hard.
Old 12-03-2017, 11:34 PM   #18
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
any updates? has anyone tried it?
Surok is offline   Reply With Quote
2017 brz exhaust vs older exhaust Joetheegyptian Engine, Exhaust, Transmission 19 04-07-2019 09:26 AM
'17 Toyota 86 Euro spec model - NA build/Street/Track Philliplo Member's Car Journals 20 11-21-2018 12:15 PM
Manual Trans gearing for 2017 model ? ToySub1946 Engine, Exhaust, Transmission 13 04-03-2017 04:41 PM
Older model parts fit 2016? JPRodney Scion FR-S / Toyota 86 GT86 General Forum 7 04-27-2016 02:59 PM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 04:07 PM
