Old 02-14-2017, 01:25 PM   #15
stevesnj
stevesnj's Avatar
Originally Posted by JoeC View Post
I read it that he could see seam welding working on a track car but as unproven snake oil on a DD.
The reason i said Snake is is because this car wasn't designed as a rigid body. You start messing with the structure like that and it will be less safe and advertise the shops that did the work then it's all just a gimmick to me. I just think this is a bad idea and unsafe and unnecessary and moronic on a DD car.
My 2016 Build thread
Old 02-14-2017, 01:40 PM   #16
JoeC
Drives: Subaru BRZ Limited
Originally Posted by mav1178 View Post
If one were ONLY stiffening the chassis and not doing anything else with it, i.e. drive it on a public road, then yes, I would agree with your statement. But since OP is asking about a DD, then your statement is wrong for all the reasons already listed.
If one gets in a wreck with a seam welded chassis, the impact would easily overwhelm your stock seatbelt + airbag's ability to protect you. You would need to reengineer the entire safety system to compensate for much higher G-forces in an impact. Even a 15MPH impact can kill you.
Plus, the "unproven snake oil" part mostly revolves around the change in crash characteristics of the car. Plus, once you stiffen the car you change the natural harmonic frequency of the car, thus introducing the "unproven" part of the problem.
-alex
I still don't understand what I've said that's wrong, hahha. no worries. I'll just keep reading like a normally do.
JoeC is offline   Reply With Quote
Old 02-14-2017, 01:41 PM   #17
JoeC
yeah, I see what you mean.
Old 02-14-2017, 01:48 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Basically what Steve said. It's a gimmick because it only stiffens the chassis without any of the other benefits that a normal roll cage would provide (passenger protection, etc.), and is even more dangerous on regular roads.
Old 02-15-2017, 01:16 PM   #19
wparsons
wparsons's Avatar
Repeating for emphasis
Originally Posted by wparsons View Post
There's also a lot of other points of deflection before the chassis is the weak link, so unless you've replaced ALL the rubber bushings with bearings there's still something MUCH easier to do to improve feel and suspension precision.
I don't think the chassis is weak enough that there's significant deflection in street use. This isn't a flimsy 80's unibody
flickr
Old 02-15-2017, 07:16 PM   #20
Racecomp Engineering
[ame="https://www.youtube.com/watch?v=ulEisLcFEl4"]MGS2- Snake Game Over - YouTube[/ame]
Old 02-15-2017, 08:53 PM   #21
mrk1
Drives: Sterling BRZ Ltd
Seam welding can go along with roll cage builds, car is stripped down and needs paint anyway.
Does it work, yes. Is it at all in anyway practical for a full interior street car, no.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
wparsons (02-21-2017)
Welding advice radroach Other Vehicles & General Automotive Discussions 23 12-16-2014 07:01 PM
Cost of O2 sensor welding pseudo Engine, Exhaust, Transmission 4 09-25-2014 10:29 AM
Tig Welding Freedom AFRICA 2 05-28-2014 09:55 AM
Tig welding Gen Southern California 0 04-25-2013 09:15 PM
Welding/Fabrication shops on the east side? seven Northwest 0 11-24-2012 08:11 PM
