Only happy when it rains.
Drives: series.blue
seam welding Chassis
Seam welding chassis.
I always wonder if this type of thing is actually worth it for us normal people. It always sounds interesting to me, and there are all sorts of articles about legendary japanese tuners that go nuts on chassis and weld the ever living daylights out of them and how it makes it so much better. But is it really worth it and how much would it actually cost? I doubt it would be cheap. |
#2 |
hey you, yeah you <3
Drives: 2014 37J FR-S
is this to make more sturdy? Any benefits to cornering?
#3 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I believe the general idea is to lessen chassis flex to make inputs sharper and allow the parts that are supposed to move be the only ones that do.
| The Following User Says Thank You to finch1750 For This Useful Post: | Packofcrows (02-13-2017) |
#4 |
Drives: 2013 Scion FR-S 10 Series
I assume it would stiffen the structure substantially, but it's not practical on a road car because you'd have to strip the shell down to bare metal along the seams in order to weld it, and then you'd need to paint the welded seams to prevent corrosion. How willing are you, or any sane person, to do that?
| The Following User Says Thank You to RJasonKlein For This Useful Post: | wparsons (02-14-2017) |
#5 |
Drives: 2005 Toyota Camry
I will be the first to say RIP to you when you get in a wreck, if you use this on a street car.
Things like this change the crash characteristics of the car, to the point where portions of the roof may cave in and cut your head in half. I'm not being a ****, I've seen it happen. -alex |
#6 | |
Even with an entire 20+ person bodyshop at his disposal, we gave up after painting the chassis and left the insides of the car barren. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | RJasonKlein (02-14-2017) |
#7 |
It might do good but it's not cost effective. On an ae86 or na miata? Probably notice but there are better ways to go faster.
Drive upgrades. Don't buy them.
| The Following User Says Thank You to fatoni For This Useful Post: | Kylebrz (02-15-2017) |
#8 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Have seam welded a Civic racecar before. Not fun.
86s are more than stiff enough for street use. If it's a racecar, get a cage and call it a day.
- The Ancient BRZ Sacrament by Zaku |
#9 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#10 | |
Drives: Subaru BRZ Limited
I don't think it's a good idea for the reasons others brought up about the diminished crash protection but it seems like a completely reasonable way to stiffen the chassis. |
| The Following User Says Thank You to JoeC For This Useful Post: | why? (02-19-2017) |
#11 |
Depends on your definition of reasonable... to seam weld it properly will take weeks of work. Unless you have a specific goal in mind (ie you've measured too much deflection in a given situation and want to eliminate it) and are going to measure the improvement it's simply not worth the effort IMO.
There's also a lot of other points of deflection before the chassis is the weak link, so unless you've replaced ALL the rubber bushings with bearings there's still something MUCH easier to do to improve feel and suspension precision.
| The Following User Says Thank You to wparsons For This Useful Post: | why? (02-19-2017) |
#12 | |
Off Topic
#13 | |
I think it could be equally effective in both applicaitons but I agree with you. Obviously not advisable for a DD for all the reasons you (and others) described |
#14 | |
If one gets in a wreck with a seam welded chassis, the impact would easily overwhelm your stock seatbelt + airbag's ability to protect you. You would need to reengineer the entire safety system to compensate for much higher G-forces in an impact. Even a 15MPH impact can kill you. Plus, the "unproven snake oil" part mostly revolves around the change in crash characteristics of the car. Plus, once you stiffen the car you change the natural harmonic frequency of the car, thus introducing the "unproven" part of the problem. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | why? (02-19-2017) |
| Welding advice | radroach | Other Vehicles & General Automotive Discussions | 23 | 12-16-2014 07:01 PM |
| Cost of O2 sensor welding | pseudo | Engine, Exhaust, Transmission | 4 | 09-25-2014 10:29 AM |
| Tig Welding | Freedom | AFRICA | 2 | 05-28-2014 09:55 AM |
| Tig welding | Gen | Southern California | 0 | 04-25-2013 09:15 PM |
| Welding/Fabrication shops on the east side? | seven | Northwest | 0 | 11-24-2012 08:11 PM |
