Old 02-10-2017, 09:14 PM   #15
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
New to driving?
Old 02-10-2017, 09:24 PM   #16
8R6
8R6's Avatar
Drives: FRS
Originally Posted by HKz View Post
going under 5 MPH to avoid scraping/bottoming out has nothing to do with the car being an easy manual to drive..our twins can be clunky especially at low speeds
what i meant by "easy to drive" included having to drive at low speeds, stop and go, etc. Our cars can easily be creeping at like 3mph without needing the clutch pedal work. my place has an insane driveway ramp upwards and then sidewalk and immediately down to the street basically being a giant speedbump. i scrape for sure, but i try to minimize the scrape as much as possible. slip the clutch to get to like 2-3mph and after that its just slight throttle control.
8R6 is offline   Reply With Quote
Old 02-10-2017, 09:30 PM   #17
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
MOVE !
There is no better car out there. There are better living/parking situations.
Additionally...you won't own this car for long without scraping it's front end once in a while...it's inevitable.
ToySub1946 is offline   Reply With Quote
Old 02-10-2017, 09:36 PM   #18
swarb
I personally have no problems with the car being "clunky" at low speeds.
Car doesn't have a heavy clutch, a grabby clutch, or much torque...
The problem with your setup is you have soft springs, soft shocks, reduced travel and lowered too much for the spring rate. I'm on coilovers adjusted lower than any springs go and never have problems bottoming out at low speeds.
Old 02-10-2017, 09:57 PM   #19
ghostzfh
Drives: 2016 Scion FRS Halo
I would slip the clutch because lurching causes damage to the entire drive-line of the car (i.e., engine to the transmission to the wheels, basically entire structure of the car).
ghostzfh is offline   Reply With Quote
The Following 2 Users Say Thank You to ghostzfh For This Useful Post:
cat94 (02-10-2017), JD001 (02-12-2017)
Old 02-10-2017, 10:10 PM   #20
cat94
Drives: '17 86
Originally Posted by Summerwolf View Post
New to driving?
Yep, best to ask when you are unsure.
Originally Posted by ToySub1946 View Post
MOVE !
I can live with that. Already scraped a few times, but doesn't hurt to minimize that count.
It actually only lurches on cold starts, even after a few minutes warming up the engine (presumably because the rest of the car is still cold). But, I'll go with slipping the clutch as if I were reversing out of a parking spot.
Slipping at low speeds > lugging
cat94 is offline   Reply With Quote
Old 02-11-2017, 01:49 AM   #21
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I welcome you to try the 6 speedbumps in my complex...I'll take pictures later..
regardless, bottoming out was poor wording on my part as my setup has never truly bottomed out, but yes the soft shocks are indeed causing the chassis to rebound enough to hit the bump though I don't think the lowering springs have affected me too much as my first FRS at the stock ride height hit the bump just as often....and you're right, coilovers would avoid such a bounce but for DDing that is like the only benefit lol (besides better stance)..nty..not to mention I would have to initially drive slower over these bumps too
HKz is offline   Reply With Quote
Old 02-11-2017, 02:57 AM   #22
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Use more revs and slip the clutch when the engine is cold.
Scrappydoo is offline   Reply With Quote
Old 02-11-2017, 04:49 AM   #23
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
7000rpm, 3mph, drift over it
JK.
FR-Sky is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-Sky For This Useful Post:
8R6 (02-13-2017), finch1750 (02-12-2017)
Old 02-11-2017, 05:22 AM   #24
JD001
JD001's Avatar
Drives: Subaru BRZ
Slipping clutches is part of life, just don't ride the clutch once you're over the danger stall zone as that will wear your clutch quickly.
The Following User Says Thank You to JD001 For This Useful Post:
Summerwolf (02-11-2017)
Old 02-11-2017, 08:11 AM   #25
Summerwolf
Panda Trueno
Summerwolf's Avatar
I would take a small amount of clutch modulation over lurching / lugging. You will learn to feel it out over time.
The Following User Says Thank You to Summerwolf For This Useful Post:
cat94 (02-12-2017)
Old 02-12-2017, 01:22 AM   #26
Andr3w
Andr3w's Avatar
Drives: Corolla
From what I have been told, it's alright to slip the clutch at low speeds and low revs for a short time.
Another trick is to blip the throttle a bit then modulating the clutch to control the speed.
I am also working on my stick skills, too. Looking to learn how to heel and toe this summer.
I think a nightmare situation for me would be to parallel park on a steep incline, especially since I don't have power steering haha.
"Initial D and chill?"
Andr3w is offline   Reply With Quote
Old 02-12-2017, 03:56 AM   #27
JD001
JD001's Avatar
Drives: Subaru BRZ
Constant revs when slipping the clutch to stop the jerking or wanting to stall.. similar to a hill start or when crawling in traffic going up a hill.
Old 02-12-2017, 04:02 AM   #28
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Id slip the clutch. My driveway is garbage and has a wierd crown so I have to go very slowly to avoid scraping when there are 2 people in the car. But if you work on super small pedal inputs it can be driven that slowly without the clutch, just takes a fair amount of practice
2013 FRS buzz when clutch partially engaged/slipping bemgikim Issues | Warranty | Recalls / TSB 13 05-29-2017 09:47 PM
Need clutch suggestions for daily driving a Turbo FRS CamFrs Engine, Exhaust, Transmission 8 04-04-2017 06:27 PM
new clutch slipping already? nickmerronesucks Engine, Exhaust, Transmission 12 10-07-2015 02:33 PM
Clutch grinding when driving? J-Money Issues | Warranty | Recalls / TSB 0 08-12-2014 03:22 PM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 09:56 AM
