Old 02-07-2017, 01:49 AM   #15
steve99
Originally Posted by Inspir3dk View Post
Yeah I thought OFT gets rid of P2096 as well. At least from what I read on other threads and other's experience.
you should not trip P2096 cel code its a real code and indicates lean condition
Is 02 spacer in the REAR 02 sensor, never put spacer in front 02 sensor.
could be leak
incorrectly installed front 02 sensor
use you mates OFT log
AFR
commanded AFR
LTFT (long term fuel trim)
If you have high positive LTFT and the AFR is leaner than Commanded AFR at low to medium RPM , but ok at higher rpm then you almost certainly have a leak at haskets joints or cracked header or incorrectly installed 02 sensor, they must screw in in all the way till ring is tight.
Use a thread chaser to clean up header threads if necessary
The code you thow for catless header is P0420 cat efficiency, this is the only code you should disable on NA tunes unless your running flex kits into rear o2.
Old 02-07-2017, 12:07 PM   #16
Inspir3dk
Drives: Red 2016 BRZ Limited
could be leak
AFR
commanded AFR
Thanks for the info and instructions! We'll plug it into the OFT and check for a leak later today when I'm at his garage.
Inspir3dk is offline   Reply With Quote
Help installing a header & front pipe rns294 Mid-Atlantic 3 06-24-2016 09:52 AM
P0175 code after installing intake VictorKassil Issues | Warranty | Recalls / TSB 5 04-14-2016 08:36 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 05:30 PM
Need to replace FP/MP gasket when installing header? 1Cor10:23 Engine, Exhaust, Transmission 16 04-24-2014 05:09 PM
CEL Code P2096 w/ exhaust only ShutterSpeed Issues | Warranty | Recalls / TSB 7 12-03-2013 01:59 AM
